Rear tank fuel wierdness, front works great
LONG STORY SHORT: Front tank runs great, rear tank sputters and stalls
So I have a 1994 7.3 IDI Turbo.
The beast ran just fine until about a month ago I decided to fill her up and take her through the car wash. This is when my problems started.
I ended up overfilling the rear tank, causing it to leak everywhere. Now whenever I run off the rear tank I get surging, sputtering and stalling. Front tank works fine.
So far I've eliminated
-Vacuum situation in the rear tank (ran with no gas cap, still problems, took the drain off the top of the tank, still problems)
-Felt the selector valve move when I switch from front to rear, so that seems to work
I think it could be either water in the tank (car wash) or there's air getting in there before the selector valve (because the front tank works great). It could also be a clog.
I have 0 experience with fuel systems, so does anyone have any suggestions on where to start? Thanks!
Received 3,102 Likes
on
I found a pinhole leak in the sender by submersing it in water and blowing on it. W00p! It was 15mm above the round plate part, on the outside. I'm gonna JB weld it and finish tomorrow. Such a small hole causing so many problems... I couldn't even see it, all I could do is see the air coming though.
dziwei
06-15-2018 08:53 PM
Drunken_Chewbacca
05-08-2018 03:31 PM
