1949 Muffler
I bet a tractor supply has round mufflers as well.
Y blocks like a true dual exhaust, no X or H pipe, and smithys or porters from what I'm reading. Have the Rams horn manifolds (finally) just need to get the rest of the parts together.
Tractor supply was high in price and online only, most were tractor mufflers. If you go to autozone there is a book in the muffler area. In the center of the book are 4 pages of pictures of mufflers. There are about 6 round mufflers available. Most are around $27 bucks.
I used glass packs that the guy had at his muffler shop. Round.
I put on 18" long, more quiet than I thought they would be.
On a 239 1950 F2.
Happy with them. About $60 for the pair.
On a 239 1950 F2.
Since you made a point of asking Bigwin for the part number on a muffler that he had bought a week or so earlier, after you stated that you bought one at Autozone and Ross requested the part number, I expected you to post the part number, NOT 'there are pictures in the book'.
Here harleymsn, I will spoon feed you, number is 11017 from autozone. Would you like the address of your local store? its not an exact match but it works and is pretty close and CHEAP. Tractor supply lists them as diesel and vertical and horizontal so I am not sure if the guts are different. I wasn't going to take the chance BUT, they didn't have any that were close in size or cheap so it didn't matter.
Thanks for providing the part number. I was looking at a couple of different walker mufflers last night, and it helps to know which one will work for certain.
FTE isn't one of them.
I agree. This is completely out of line. Go back and look at the hundreds of posts you've made here over the past few years (including your previous login name of johnfin). If anybody has been "spoon fed", it's you. You ask questions, we give you the answers as best we can, you scoff back and argue and ALWAYS talk about how expensive the solution is. Never once have I seen you actually try to answer somebody else's question or try to help somebody else. Never once have I even seen you say Thank You to anybody. Harleymsn is our friend. He was trying to help.
#30
Received 1,344 Likes
on
