Help!! New Batteries and Alternator... still no charge =(
Yep. When I did my 3g upgrade I took the alt from the jy to autozoo. They said bad no voltage at all. Took it the Advance test good at 14 volts. Verified when I put it on 13.7 at idle
That wire is associated with the dash warning light. So the owner's manual should mention which fuse is for that light. Also, I've read elsewhere that when that light burns out, it can affect the exciter circuit to the alternator. Does the light come on when you turn the key to RUN (engine OFF)?
Check the bulb for the charging system failure warning light.
You're not even getting a WTS light?
If no one with a '94 EVTM chimes in, I'll check my '95. It's for a PSD of course, but much of the circuitry for things that aren't specific to the type of engine (such as charging, accessories, etc.) are similar, so I'll check that for what fuse to check.
Are you checking for voltage at the terminal on the green/red wire with the key in RUN?
Urban Monkey
10-08-2015 12:17 AM
Andy_W
6.4L Power Stroke Diesel
11-17-2014 08:58 PM
wisconsin
1997-2006 Expedition & Navigator
02-03-2008 09:59 PM
Redneck80
12-21-2003 05:17 PM
