looking at an 04 f350 6.0 - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Log In
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Old 07-03-2015, 04:50 PM
ufvj217 ufvj217 is offline
ufvj217 has a good reputation on FTE.ufvj217 has a good reputation on FTE.ufvj217 has a good reputation on FTE.
So i went and drove this, has low miles (39k) but the 04 and 6.0 kinda scares me. What should i look for, or should i steer clear? It drove well, and if i get it, I'd hope to get a very long life out of it (mainly as a daily driver, won't be towing all the time with it or beating it up dailywith heavy loads or anything)
looking forward to opinions from you guys. Cosmetically it had some scratches but for now it would be fine and eventually i could paint it, maybe use it as an excuse to put a newer tailgate and 08 front end on it!
http://www.billcurrieford.com/inventory/2004-ford-f-350sd-lariat-4wd-4d-crew-cab-1ftww33p44ec02903
Old 07-05-2015, 07:37 PM
Bump!!!! Lol
Old 07-05-2015, 07:46 PM
bigredtruckmi's Avatar
bigredtruckmi bigredtruckmi is online now
bigredtruckmi has a great reputation on FTE.bigredtruckmi has a great reputation on FTE.bigredtruckmi has a great reputation on FTE.bigredtruckmi has a great reputation on FTE.
David Dankenbring
1st. Get a carfax report. Check the underneath. Ask for service records. If chipped and otherwise stock. Stay away. If built after 03 of 2004 basic engine should be ok.
__________________
red 04 F250 build date 04/04 6.0 PSD (retiring to farm work)
2013 gulfstream canyon trail fifth wheel Aztec edition 40 ft weighs in at 13K
Vietnam Vet/ OS1 USN/USNR retired 26 years
2015 CC f350 6.7 max tow lariat pkg. long bed AKA big blue
Dave and Joyce
Old 07-05-2015, 08:41 PM
Quote:
Here's a link to the carfax. Looks like its always been in FL, so should be no rust.
I didn't see a chip or anything, looked 100 percent stock.
Door jamb photo shows 01/04 as the date.
http://www.carfax.com/VehicleHistory/p/Report.cfx?partner=BDW_3&vin=1FTWW33P44EC02903
Old 07-05-2015, 08:55 PM
David Dankenbring
There should be a tag on the engine for its build date.
__________________
Dave and Joyce
Old 07-05-2015, 09:00 PM
I will check tomorrow. So if completely stock and built in 03 or 04 stay away you said? Or good?
Old 07-05-2015, 09:05 PM
David Dankenbring
Look at the oil filter. If it looks oem filter cover then more than likely used Ford filters. If can get into service records check to see if fuel filters was changed ev r y 10K. These engines are very touchy on fuel cleanliness and volumes.
I have found on a 3k run and getting fuel wherever I have very dirty fuel filters. A friend of mine said he normally sees injectors put in by his shop by 150K. I have 200k and no problems.
__________________
Dave and Joyce
Old 07-05-2015, 09:09 PM
David Dankenbring
If built in early 04 should be good but get more info as I put in other post. Just about sounds too good to be true. But they are out there!
__________________
Dave and Joyce
Old 07-05-2015, 09:12 PM
David Dankenbring
Might want to ask this question in the 6.0 engine area. There are some techs monitoring there sometimes.
__________________
Dave and Joyce
Similar Threads
F350 04 6.0L No start - need some help ktownf350 6.0L Power Stroke Diesel 15 06-17-2015 08:51 PM
04 F350 (6.0) NOT STUDDED...?? SOLOLUCKY General Diesel Discussion 8 03-23-2015 08:46 PM
stalls when cold olyellow 6.0L Power Stroke Diesel 14 06-23-2014 11:46 PM
04 f350 turns over but won't start! grileyh 6.0L Power Stroke Diesel 11 05-31-2014 10:43 PM
04/04 6.0 X Drivetrain rumble on acceleration DFW1 Excursion - King of SUVs 3 01-25-2004 09:56 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
