Transmission stuck in tow haul
07-03-2015, 01:25 PM
on
04 f250 6.0 my transmission stays in tow haul mode after I turn the overdrive back on. Light turn on and turns off with the switch but rpm don't change what can it b?
07-03-2015, 02:33 PM
07-03-2015, 02:43 PM
on
My truck fills sluggish when driving and the transmission shifts like it does when the tow haul is on even when it's cut off. I'm running 1500 rpm at 55 mph when my neighbors f250 runs 1000 at 55mph.
07-03-2015, 02:49 PM
1500 RPM at 55mph sounds perfectly normal for a 6.0/5R110W in OD, with 3.73s and stock sized ~31.5-33" tires. You'll need to provide a lot more information to make the comparison with another unspecified F250.
07-03-2015, 02:51 PM
on
Ok so what would make it fill sluggish
07-03-2015, 02:54 PM
Old fluid, bad solenoids, low engine voltage, PCM-only tune, a whole lot of things. What's the maintenance history on the truck? Trans flush and external filter change interval is 30k miles.
akhunter02
1999 to 2016 Super Duty
05-15-2012 03:35 PM
lawmac2005
12-09-2010 05:56 PM
crownvic
02-10-2009 05:55 PM
Schmitty133
01-11-2009 04:09 PM
Delawhere?
03-24-2005 01:44 PM
