2011 6.2L Brake Pads Replaced at 50k
Replaced the brake pads this afternoon. After a few hours, I completed the job with a cold Amber and aching back. Make sure to turn the steering wheel to the desired angle to work around the passenger and driver side rotors. The original pads were fine but the new Napa Premium pads look thicker. So, I started with the passenger side and completed driver side. While replacing the pads, I double checked to see the rotors and calipers were in working condition. I lubricated the caliper pins and the desired areas where the pads ends connected on the calipers. Lastly, make sure to screw one caliper retaining pin half way before fastening them. Good luck with your pads and reward yourself with a cold one… Wheel bearings are next.
If the pads were ok why did they need replacing? I always replace rotors or resurface them when replacing pads. Good luck!
on
To many years of freight trucks delivering to my shop.
Denny
Nice job Denny,
Jeeze, that house looks just like one we looked at buying up here. I had to double check your location to make sure. From this angle it looks like that front corner of the roof is waiting to "catch" some delivery driver that backs in without paying attention.
Denny
Dolby4040
06-09-2004 09:56 AM
