IFS with a Y Block?
IFS with a Y Block?
Have any of you guys installed an IFS and still ran a Y-Block?
The motor in my truck is still strong, and it has the stock Overdrive behind it. My plans have been to run a dropped axle and some Posies springs, but by the time I do the math, and consider potential resale value, I think that I would be better off to go with an IFS.
I did talk with Steve, at Industrial Chassis, and he confirmed that he's done it before with a front engine mounted Y Block, but I was curious if anyone's done one with a Mustang II type crossmember and rack and pinion.
Feedback is most appreciated.
I just rencently put an '03 crown vic craddle in mine. The only thing I had to do to my Y-block was remove the oil breather on the side of the block. I could have just shortend the tube an inch or two because it was hitting the power stearing lines, but I decide to just remove it and blank off the hole. We did the intire install with the engine in place.
I did not have to touch the motor at all other than the oil breather, still on the front engine and bellhousing ear mounts. I am running a '65 9-inch rear and I put adaptors on the hubs to convert from the 5x5.5 to the 5x4.5 bolt pattern so I can run the same rims front and back. This lined the front and rear widths perfectly. I am running 235/55/17's all around and this fits perfect in the wheel wells for my taste. We did move the craddle 1 1/8 inch forward to center the wheels in the front.
A couple questions I have:
bchrismer: Why do you think a buyer wanting a truck with stock driveline would not also rather it have stock axle/suspension than IFS?
Blue55: How are you venting the crankcase if you blocked off the vent tube? I have seen unvented crankcases that exploded when blowby fumes accumulated inside. It also allows water vapor to boil off and escape. That tube has a very important function.
LOL. AXracer, I figured that question would come up.
I actually believe that the engine and overdrive transmission will be a detractor to a future owner. Most folks tend to be scared of old motors and transmissions that they are not familiar with. Me, on the other hand, in the past 3 years have put about 15,000 on my stock '40 1/2 ton stake truck.
Whenever it is time for the truck to go down the road, I am sure that there will be an option for the new owner to take it with or without the motor and transmission.
sweet ride. I have driven mine the past 8 years with the stock suspension but it was so worn out, and it is my daily driver (over 1,000 miles a month) so I finally went to the IFS and new rear springs. The stock suspension was making everything else rattle too much anyway. As far as the venting, right now I only have the oil filler tube vent breather and things are going well so far. I got the idea for doing it from the spare 272 I have, it had a blank out plate on it as well.
maverick600
06-10-2014 05:44 PM
ARMORER
General Automotive Discussion
20
10-26-2005 01:43 PM
