2007 EDGE Mirror issues with KEYFOB
Hi,
Anyone else having problems with drivers side mirror moving out far left and clicking when key fob is used to open the doors? The mirror has to be moved manually back since the mirror controls do not work. I've heard several things, disconnect the battery, reset memory presets and replace the PCM, but all are different solutions and nothing has worked (I have not replaced the PCM). THANKS
