5.4 2v timing marks
5.4 2v timing marks
I'm getting ready to do the timing set on my 03 Expo. I can't find much info on the cam timing marks. Is there a dot? If so, do they both get set to the two shiny links like the 3v? The few write ups I found call for the crank keyway at the 12 o'clock position where as the 3v called for 11.
I know this motor has the issue with stripping plugs out. What has everyone determined for a torque spec?
Any info is appreciated.
Going to do intake gaskets, v-cover, plugs, boots, t-set w/all associated seals, p/s flush, t-stat and coolant,fuel filter,brake flush, and of course an oil change.
Gotta keep mamas truck running, and more importantly, the boat tow rig.
