Ford econoline e350 RV overheating on traffic
#47
No way to see both working because you would need another hole in the intake water jacket or some other convenient place or a tee and that is way too stupid for me...Yes ..once you unplug the Factory POS you need to mount the New guage wherever you want and you Install the sender in the factory location...give it 12 V and maybe a light and your are done...there are many ways to do it ...You can even buy a stick on Pod type...something like this....Gauges - Speedhut
Or Ebay
Or Ebay
#48
Or Ebay
Or Ebay
#49
check when it's hot in traffic
220 is high but tolerable, 250 definitely is not.
#51
That's high for an iron block but if it's not puking coolant I'd be semi-ok with it.
How long does it take to get to that temp?
So what your saying 230 is fine? What if it goes pass that when weather is hotter? should I be concerned?
#52
For an iron motor, that's about the upper limit but as I said, if you are not puking water out, you are probably ok for awhile.
This may seem odd but what oil are you using and is it topped off? How old is it?
Synthetic will help if you are not running it.
Oil temp is as important as water temp, if not more.
I have run iron motors at 230 for extended periods with no harm. But they were chevy's
#53
So is there anything I could do to have temp go lower?
#54
did you replace the lower radiator hose , when they are old they can collapse and reduce the coolant flow ?
If all else has not worked to lower the temperature you are left with installing a higher flow waterpump and or a larger radiator. You have a large motor in a small space it needs all the help it can get. Do you have a tranny cooler ? If not install one the bigger the better this will take some of the cooling load off the main radiator.
Good luck problems like this are never easy .
#55
#56
Exactly....I would also consider getting a better ( read Aluminium ) Rad ..I realize you installed a new one But it seems you need a higher cooling capacity ...Or have you thought about switching to Electric Fans ? That means eliminating the stock fan and Installing Electric ones with their own controls ? A lot of Hot rodders do it ....
#57
#58
I feel bad that your wife influencing your decision...But I am talking about something like this or 2 of them ...and you remove your Stock Clutch Fan and rely on the electric ones instead....this is Not a new concept....
http://www.summitracing.com/int/parts/flx-398/overview/
#59
your wife is right it is a money pit , but once it is sorted out it will be a fairly reliable vehicle.
check the timing , retarded timing will make motors run hot also.
230 is to hot ,your engine and tranny will thankyou if you can get the temps down.
also is your overflow tank working , do you see a rise in the fluid amount when warm and a reduction when cold ?
#60
