Ford econoline e350 RV overheating on traffic
#31
Yes ....I am opposed to whatever that crap is....I only use OEM parts on my Trucks.....I have no fear of paying more...I make money....everyday....More than you can count I'm sure...As far as the OP goes..you connect the sender from the guage to the same spot the factory one is...On my 77 460 it is just above the thermostat housing on the drivers side...it has a wire connected to it...Make sure you use T-tape on the new sender and do not overtighten it ....
#35
Guys I know that you're both passionate in helping me with this issue. Can we just stick with the topic and can we just get a long?
Blageurt my thermostast is on the front and on the passengers side I couldn't follow where the current gauge is connected. I was thinking it would be inside the dog house?
Vettex2 are you saying that I could just use ordinary tap water or RO/DI and not use water wetter? Since you said that these engines runs between 190- 200 wouldn't the water boil and be bad?
#36
#37
All 460's have the exact same thermostat housing and engine layout...Up to 1978 they were Internally Balanced and after that they were externally balanced ....Meaning you cannot interchange flywheels and Harmonic balancers...otherwise they are almost identical...I just went outside and looked at my 77 460 ...and it is at about 3 or 4 o'clock if you are looking at the disribiutor in the plan view... it is underneath the distribiutor... But I have an Edelbrock Intake( square bore Aluminium) ....Yours might be in the back of the motor...I do not know...I have the factory DVD for 1995 and can look for it ....Mine is where I said it is ...
And for Mr Vettex ....My mother died one year ago and I own 3 Houses with very large basements...No ferrets however....I don't really like weasels
#38
I'm sure you understand the reference.
#39
Blageurt - Hope you could find that info so I could install the temp gauge.
Vettex2- Thanks I'll buy the water wetter this weekend and placed distilled water and take it for a ride and see how the temp goes.
Hopefully I'll be able to post results next week. Anything else that you could think of before the weekend please let me know so I could do it .
Thanks for all your help and keeping my fingers crossed.
#40
According to what I have, it is in the same location as I said it was.... bot closer to the Thermostat Housing since you have the stock Intake ....it is most likely under the distribiutor beside the thermostat housing ..Maybe if you remove the Distribiutor cap you will be able to see it more clearly....hope this helps
#41
#42
It may not even be running hot. Check temps before you spend money......
#43
