Differential oil seal
I'm not familiar with this seal but what sometimes happens is the seal wears a groove in the shaft such that the next seal can't do a good job. Short of replacing the shaft, the pinion in this case, polish any grooves and see if you can set the seal at a different depth to run on a clean section of shaft.
Sixto
93 E150 Chateau 5.8 191K miles
Sixto
The 8-14 in.-lbs. is basically the drag. That is how many in.-lbs a dial torque wrench will read while turning the pinion with a torque wrench on the pinion nut. That is not the amount you torque the nut to. If you only torque your pinion nut to 8-14 inch pounds you will have your pinion yoke fall off going down the road!
I ran into problems with the front yoke seal (3 times) and rear yoke seal (1 time) on my ram 3500.
The first seal we put I leaked right away.Turns out the old seal, wore just enough of a grovve on the surface of the yoke that it woul dnt allow the new seal to function.
Wh3n they replaced them, they didn't go through the whole by the book process.Basically just a tax tighhter than what it was on with and never a problem.
If you still have a leak around the yoke and it turns out to be a groove worn in the yoke shaft, you might research into a spedi-sleeve
Yoke Repair Sleeve for 9" Ford Rear - Speedy Sleeve for rear end yoke
http://www.ebay.com/itm/Yoke-Repair-Sleeve-for-9-Ford-Rear-Speedy-Sleeve-for-rear-end-yoke/151551240572?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D33278%26meid%3D24e4809c3d92432a8629807d126d7e0f%26pid%3D100011%26rk%3D1%26rkt%3D1%26sd%3D150831759525
Make sure it fits your van..
NATIONAL Part # 99181 Redi-Sleeve
More Information for NATIONAL 99138
I prefer a press to a hammer.
here's a example of how the speedi sleeve works
Speedy Sleeve installation on Jerry's 1964 Galaxie 500 XL Day 19 - YouTube
Again check your part number,, i think yours is the 181 number
61 uni
15
03-13-2009 05:56 PM
