Oil Temp how hot is too hot????
Towed I 40 westbound to Santa fe today. Air temp was 86 to 92 and on several occasions my Oil Temp on the Edge alerted. I have it set at 135 degrees. Highest reading I saw was 141 degrees (I think). No apparent ill effects or codes. Each time the Engine coolant was also elevated to the 120 degree range. I don't recall either the 6.4L or the 7.3L oil getting that hot. So, is anybody else tracking it and having similar or different readings.
If I began to exceed 245°F EOT on my truck I would start taking it easy. I haven't seen any official numbers from Ford but what I do know is the truck will self de-rate if you are pushing it too hard to protect itself. 250°F would seem a bit high for my comfort zone but I don't know the value that causes the de-rate.
I'm guessing you mean your highest temp was 241? 195 (ish) is normal operating temp for the oil.
Here's an old post from PH.
https://www.ford-trucks.com/forums/1...l#post11737463
These engines squirt oil into the skirt of the piston to cool the piston. So when you are under a hard load. Lots of turbo boost. The oil temp will climb pretty fast. I've also seen temps around 242° when pulling trailers up steep grades.
Last summer we asked about this and the response from the Ford Engineers was that 242 was still with in the design specs for this engine/oil. So unless you see something higher than that, You are fine.
In my opinion which has over 300,000 miles under 6.7 power towing, go ahead and try to get the oil to 250°, I bet you can't......
Seriously, you well know these missions compliant diesels are hot engines and actually thrive on heat to run efficiently. Cool fuel and air, hot exhaust and oil, high operating temp, and a big cooling system to keep the heat in specific range but also to retain heat for consistent parameters. 400HP makes an awful lot of btu.....
Mobil1 5-40
flash point is 420°
thermal break down starts @ 270°
SHELL ROTELLA T, 15W40
flash point 400
thermal break down starts at 250°
In any normal heavy extreme use on this planet, you will never see high enough temps to be concerned with oil temps on the 6.7
The cooling systems on our 6.7 is the stoutest I've ever seen on any vehicle. I'll rephrase that, the 2 cooling systems on our 6.7 are the stoutest I've ever seen.
It truly is overkill imo.
1 day in August some years ago, had a 2011 xlt in Phx on a 117° day. Drove to the desert, a 3 hour ride to Glamis, towing 15,000lbs, it was 114° when we got there in Glamis. (108° at 1:00 am that nite)
Left the 6.7engine running in the sun for 3-4 hours with jumper cables connected from it to my sand car, to charge its dead battery.
We took a siesta in the ac'd Toy Hauler while the battery charged up. The heat was the hottest I've ever experienced. Think i lost brain cells from that dry heat... lol.
The truck never missed a beat or overheated. Never went over normal range on the gauges.
jmo
flash point is 420°
flash point 400
jmo
I wonder, if the 6.7 design engineers had their way, I'd bet they want the engine to run hotter than they have it now. For max performance I'd like to know where the high end of the limit is and how much they had to back it down for longevity, reliability, etc....
Of course, I'm likely to be wayyyy wrong too.
I regularly see oil temps at 245 F, basically every loaded uphill pull in the summer. Temp go back down when coasting downhill so oil is not at that temp for more than a few minutes at a time.
Given that these trucks use engine coolant to cool the oil, The oil should be regulated until the coolant circuit has failed for whatever reason (fan failure, leak).
Mobil1 5-40
flash point is 420°
flash point 400
jmo
flash point is 420°
flash point 400
jmo
Actually it is not. Not when you can get the temp guage to 3/4 pretty darn easy. Radiator should be just a bit larger.
Yes I did Sam, getting along in years and making more mistakes. I even left home and forgot to load any fire arms. Loaded the bag with all the ammo and ear and eye covers but forgot to load even one gun. I was well into bama before I realized it. So, I'm the proud owner of a Glock I bought off the internet in Oklahoma City. I think by next Easter I'll be able to hide my own eggs.
