Trucks lowered but not low enough...
you should be able to get a couple inches moving the stationary mount at the front of the leaf spring up on the frame. also swap the rear shackle hanger side to side flipping them upside down. I would think that could get you 2". The other side to this is there will need to be new perches welded on the axle as these modifications will change the pinion angle.
on
Received 4,116 Likes
on
I also agree that the stance looks good. The only thing I would consider IMO would be to lower the running boards where the bottom of the boards are equal with the bottom of the fenders. That would give it an appearance of being lower, but that is just my thoughts I am sure many will disagree.
on
Yeah the whole truck is getting painted flat charcoal grey so they will match the truck. That's later this year. I want the stance and everything else done, then paint. I'm gonna look into the reverse eye main leaf if that will give me some more drop?? Looking for easiest way to get that drop. I don't want to do an axle flop, I think that will be too low.
Believe it or not my running boards were made out of bleachers. They actually look perfect. The previous owner did an EXCELLENT job cutting the to match the body lines. Most people that look at the truck never even notice they aren't factory. Contemplating keeping them instead of buying stock replacement ones?
