Differential Oil to use 6.8 V10 ?
on
Nope, not that I have seen. I just bought a new stamped one for cheap and gave it a nice paint job. Used stainless fasteners on both ends.
Thread I made with pictures
Don't miss that the fastener at 4 o'clock is an allen head...
I have the Mag-Hytec Front and Rear covers. Plus I use AMSOil:
Front Diff SVGQT 5 quarts + 1 tube ADATB
Rear Diff SVOQT 6 quarts + 2 tubes ADATB
Having the ability to check, change and add fluid without having to remove the cover was my big reason for going with the Mag-Hytec. Plus they allow for more fluid in each diff.
'08+ rear diff cover here, stock steel front cover both with Lube Locker reusable gaskets (No RTV!) and Mobil 1 oil of the correct weights in both.
I also have a temp sensor in my rear diff adapted to fit in the fill port that feeds a signal to a GlowShift Engine Oil Temp gauge, I have seen up to 225 degrees towing on a hot day.
