87 F250 460 Dies when roll off throttle
06-30-2015, 07:59 PM
on
Newly rebuilt 460 4 speed 4BBL, took her out for her maiden voyage and it dies when I let off the gas such as when I come to a stop light.
It idles well and runs well at 3k rpm. What should I check?
Thanks!
07-01-2015, 09:29 AM
on
07-01-2015, 03:05 PM
on
Idle set right? all vacuum lines hooked up correctly, stock carb or aftermarket???
07-01-2015, 03:41 PM
I am thinking your IAC valve is inop and somebody has jacked up the base idle screw to compensate. Unplug the IAC while idling and see what happens.
07-01-2015, 03:54 PM
Quote:
Originally Posted by
jas88
The OP clearly stated the engine is carb'ed. There is no IAC.
07-01-2015, 08:12 PM
on
daddylee100
Edelbrock 1406
I picked up a vacuum gauge tonight, with my cam the vacuum may be a little low. I will do a detailed tune on the carb tomorrow and report back!
Thanks
07-02-2015, 07:36 AM
07-02-2015, 08:38 AM
cx300
Edelbrock 1406
Thanks
You may need to use different springs inside the carb. When I had an Edelbrock carb on my old 1978 F150 I had the tuning kit to tweak it up. A must have accessory IMHO.
Lloyd1977
07-05-2016 01:37 PM
Go Fast
12-23-2015 04:02 PM
FC460
1999 to 2016 Super Duty
08-19-2009 04:00 PM
1990F2504604x4
07-22-2005 03:05 AM
pdtmxqc
09-07-1999 09:54 AM
