88 Fires right up then dies a few minutes later - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Bronco > 1978 - 1996 Big Bronco
Sign In
Register Forgot Password?
1978 - 1996 Big Bronco SPONSORED BY:
Old 06-29-2015, 06:00 PM
Art5's Avatar
Art5 Art5 is offline
Art5 is starting off with a positive reputation.
1988 Bronco 302/C6/4X4
Just pulled it out of storage yesterday, been in for less than a year, and after changing the oil and putting in some dry gas and about 5 gallons of fresh gas, I cranked it over and it fired up immediately. Ran at high idle for a few minutes, then as soon as the rpms dropped down it died. Started it back up same thing happened but in a shorter time. Every time I start it same problem. What could be going on with my truck?
Old 06-29-2015, 08:10 PM
greystreak92's Avatar
greystreak92 greystreak92 is offline
greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.
Run KOEO and/or KOER tests. Fault Codes should help in indicating the problem. Any time the engine stalls without being shut down with the key, the computer flashes any faults to memory.
__________________
The only stupid question is the one you DON'T ask!
Big Bronco FAQ's
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
