2015 250 rode rough so I checked tire pressure, Wow!
I'm running 68lbs in mine because if I get too much lower the TPMS will trigger the warning light. I'd like to be able to run less when empty but I got tired of looking at the light and having to clear the message on the dash everytime I started the truck.
A good method to get the proper air pressure is to draw a line across your tire with chalk and slowly drive forward on a hard level surface. At the proper air pressure the chalk will wear off even across the tire.
yes, they sure did. 35" nit grapplers in load range d. they paid for a ford dealer to reprogram and made some promises for my next set of tires. i buy a lot of truck,trailer and car tires from that store manager but i gave them hell over it. you would think a red flag would pop on their screen that shows this tire is not compatable with that truck but i guess not. i could understand it if they were a shop that sometimes also does tires
as embarrasing as it is to admit, this isn't the first time those rocket surgeons have screwed up tires for me. they put "regular" tires on a prius my wife used to have instead of the super light "eco" tires. it made the car shift funny and could cause chaos in that hybrid system. they may not know what they're doing but they fix their mistakes i suppose.
Not really. It was an 8-ply equivalent tire. http://www.tirerack.com/tires/tirete....jsp?techid=55
A little off-topic, but there is no shifting that occurs in a Prius. It's a fixed planetary gear system, there are no gears to shift! Were they the correct size?
Originally Posted by TireRack.com
Today's load range/ply ratings do not count the actual number of body ply layers used to make up the tire's internal structure, but indicate an equivalent strength compared to early bias ply tires. Most radial passenger tires have one or two body plies, and light truck tires, even those with heavy-duty ratings (10-, 12- or 14-ply rated), actually have only two or three fabric plies, or one steel body ply.
#28
So dealers can change the threshold? I have read mixed things in this.
