Lincoln/Ford 460 Heads?
D3 heads are near the bottom of the big block ford head hierarchy. Smog era heads. They can make power but need quite a bit of work compared to some of the others. Intake ports are ok but the exhaust ports need quite a bit of work. I had some on a 466 that were worked over pretty good with a lunati cam .554 int .554 ex Torquer II intake. Headers. Ran ok for what it was. 120's 1/4 in a 3700lbs car. I would try and find some good used aluminum or reworked steel heads. And not spend any time or $ on the D3's
Thanks +f100today! I just spend $100 though having the heads checked for cracks, cleaned up, re-painted and all of the smog holes corked. Is there any way to get just as much power out of these heads as other heads such as the D0VE heads? I do know you can get 375-400 horsepower out of D3VE-A2A heads.
crm318
49
07-24-2023 11:05 PM
76cougar74100
18
11-26-2007 11:01 AM
