Bucket seat frames
on
Bucket seat frames
sometime in the not too distant past... 'someone' posted a picture of the frames/mounts they made for bucket seats that went elsewhere with a hard disk crash...
so now that the cab is back upright I'm starting to play in the cab...
show me your bucket seat mounts please... I'm not finding what I want with a search
tia
john
tia
john
Received 4,132 Likes
on
Here are the mounts I made for the VW Passat seats I am using. I had a little bit more to accomplish with these mounts since the seat rails had no lower slide apparatus. Passat/Audi seats are very well built and unusually inexpensive because most people cut out a floor section to get the lower slides...these work much better.
jrock, wouldn't it had been a little bit easier if you would have welded nuts to the frame and run the bolts up through the floor into the welded nuts this way you would never have to use 2 wrenches also you could do the same with the seat frame,only reverse it put the welded nuts on the bottom and the bolt goes through the top
Are you saying put the bolt up through the bottom? But then wouldn't I have a bunch of threads showing? If I am understanding you correctly
Roy... BY ALL MEANS... reinforcement plates are needed under the floor... in an accident the bolts would pull thru that thin floor in a heart beat. I'd use 3/16 plate a minimum of 4" x 4" or larger if you want... the larger area you cover... the better the protection from pull thru.
on both of my cabs the seat had punched a hole in the floor at the driver side and the rt side, and the seat track was broken in at least 2support points on each track where the seat base bolts to the track.
so I'm thinking over build the floor(as compared to stock) as well as the seat base and seatbelt brackets
