Steering shaft u joint help! Pic
Personally, I'd do my clearancing on the header flange and leave the u-joint alone. Is the flange able to rotate to get the thinner part next to the joint instead of the fat part? Be sure to leave enough room for engine rocking and movement. You don't want that to bounce into the shaft while driving.
Cant tell if it would work from the pic but maybe a coupler on the rack so the lower u joint would be moved up closer to the column..or a 3rd joint may be needed..or cut the collector off and extend the outlet of the header lower. I did that with a set of headers on my truck #1 build. Plans are to get them jet hot coated.
A longer column with a shorter intermediate shaft might have been better arrangement, but the needed clearance is so minor that I'd either buy thinner jam nuts or put them on a bolt with another nut and grind the upper 1/2 the corners off, then lightly notch the header flange. I'd want at least about 1/8" clearance, engine movement shouldn't bring them any closer together. Did you drill dimple the shafts where the set screws contact?
A longer column with a shorter intermediate shaft might have been better arrangement, but the needed clearance is so minor that I'd either buy thinner jam nuts or put them on a bolt with another nut and grind the upper 1/2 the corners off, then lightly notch the header flange. I'd want at least about 1/8" clearance.
Ax,
how would a longer steering column and shorter shaft change the position of the u joint?
I'd want an inch, myself. There shouldn't be any way, under any circumstances, that the engine can touch the steering. Cooking the joints with exhaust heat isn't going to do them any good, either.
It would kick out the angle of the intermediate shaft. That's why I went with the longer steering shaft. I'd get as much clearance as possible as rubber engine mounts deteriorate over time.
