Steering shaft u joint help! Pic
I pushed the u joint further down in the splined output shaft and now it clears. It's really close, so I think I'll grind down a little header flange a little. If that's not good enough, I might shim the rack n pinion a little to change the angle just a smudge. This isn't permanent, I just want to steer so I can start it and go through the gears and check my transmission vacuum line and brakes.
I wish I would have thought of deleting the whole mess through welding. So, ....or, leave the set screws in place, grind them flush, and then weld the shaft to the u-joint.
If it isn't permanent, don't weld it. There is more than enough space on that header flange to grind a nice V notch in it and get all the clearance you need. If you weld and then find you need other adjustments, you may well be in real trouble, or even have wasted the u-joint.
I'd grind in along the same lines as the shoulder on the header bolt, about an 1/8 of an inch away, then come straight in from the shaft to meet the other cut. That should give plenty of room, even if you have to move the joint up again.
In a fantasy world maybe, but without different/heavily modified headers or drastically offsetting the engine, (or swapping in a I-6 ) there is no way to get anywhere near that much clearance. Engine torque movement is rotational around the crankshaft and with commonly used engine mounts it's likely to move the clearance apart rather than closer together. Except for a highly modified torque monster motor today's engines don't really move that much, production engine compartments have gotten a lot tighter, they can't be jumping all over, so old rubber mounts have been replaced with much more controlling engineered urethane pads. Those look to be SS needle bearing U joints, so damage from heat soaking shouldn't be an issue, but welding would be.
Did you read what Borgeson had to say about welding U joints? Plus you can't weld SS to mild steel, so you would need to buy mild steel u joints. There are better solutions.
My old setup had an eyelet type of fitting welded to the chassis rail. The bar fed through it and another set of unis ran another piece of rod to the uni at your column.
Like this (not a very good picture of it, but you can see the chrome thing to the left. This cleared the exhaust in this instance (ignore the welded joints- the whole thing was taken out, but that may be an option?
another example (not my truck- though I wish it was) I just typed in "support DD shaft" in google and got a whole heap of pictures of women in large bras! Heheh. I'm innocent! Really!
#29
#30
These are the headers that fit so I went with those. Seems like if it's not one hurdle, it's another.
