Heating up - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign In
Register Forgot Password?
Heating up
Old 06-27-2015, 07:50 AM
Firefighter12 Firefighter12 is offline
Firefighter12 is starting off with a positive reputation.
Heating up
I have a 95 f350 7.5l Crew cab with 157000 miles . I'm new to the site but have always looked on here when issues arose with the truck. My current problem is that when I accelerate very hard up to about 70 mph the temp climbs up to well in the m of normal as soon as I let off the temp comes back around the o where it normally stays. Also on a 95 degree day when idling for a long period of time with a/c on it keeps climbing up. A little history on the truck I have owned it for about a year I bought it from a friend who owned since new.in that time I did all the usual maint. Tune up and trans rebuild also just revealed timing cover and timing chain. The truck also sat for about 2 years with rare trips to go get feed. I know this is kinda a long post but I was trying to give as much info as possible thanks
Old 06-27-2015, 09:49 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has much to be proud ofFORDF250HDXLT has much to be proud ofFORDF250HDXLT has much to be proud ofFORDF250HDXLT has much to be proud ofFORDF250HDXLT has much to be proud ofFORDF250HDXLT has much to be proud ofFORDF250HDXLT has much to be proud ofFORDF250HDXLT has much to be proud ofFORDF250HDXLT has much to be proud of
the factory gauge is working correctly as long as it's reading anywhere within the "normal" range and not overheating/boiling over.
if your looking for accuracy in engine coolant readings,then you'll need an aftermarket gauge.
__________________
Log Truck: '93 F-Super Duty (F450) XLT 1st Gen Navistar 444ci IDI Diesel w/ Intercooled 2nd Gen Banks Sidewinder Turbo, E40D, 5:13, Dually, 16' Dump & Auto Crane.
Chip Truck: '93 F250HD XLT 4x4 1st Gen Navistar 444ci IDI Diesel w/ Intercooled 2nd Gen Banks Sidewinder Turbo, E40D, 3.55, Dually, 9' Dump & Plow.
Old 06-27-2015, 09:34 PM
I have used a later thermometer on the thermostat housing o on normal is about 185 after the thermostat opens and it has a 195 thermostat. So normally it runs about 185 but it concerns me that the temp rises on up when I get on it hard or let it sit idling for a period of time.
Old 06-27-2015, 10:29 PM
Mike1 Mike1 is online now
Mike1 is starting off with a positive reputation.
It could have old coolant. It could have a weak tensioner causing belt to slip at high rpm. It could be a weak clutch on the fan. It could be a weak water pump. It could need a good flush. Maybe the fins in the radiator are clogged. There's a lot of things to check.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
