Cracked Radiator
hard to say man.. from the dealer your looking roughly $370 for the rad.. (price varies by area as ive found out).. but you can get them cheaper elsewhere.. always heard all aluminum was the way to go if you replace it.. but when i had to i was in a hurry.. being that your in texas.. mishimoto could be the better way to go
ive never been one to put much faith in "repaired" radiators.. i know theres ones out there that have done it.. but always looked at it as your putting a band aid on something that could fail in another spot later..
Quick connect fittings just screw out of the old radiator and into the new mishi. No issues there. They do however require a special release tool to get the lines out when pulling the old radiator. Standard disconnect tools won't fit. Lines just push in and click when installing, no tool required.
Another tip, check Ron's radiator replacement video on you tube. The mishi instructions (they include a link to a web video) is much more involved. The rad can be easily replaced without pulling the grill, CAC, or the fan.
When the Mishimoto was delivered with no quick connect fittings in it, I tried to get some new ones before taking anything apart. Had no luck finding any, unless I wanted to buy a rad from Ford and take them out of there.
I can't look right now but I believe the line on the driver side is only 16-20in long and goes to the filter. I think the cleanest way to fix it would be to replace that short line and use whatever NPT adapter is necessary at the radiator if it needs one. Another option, You could cut the line and use a brass compression fitting on the longer, straight section to splice a new end that will fit the radiator. I'd reuse the remaining good quick connect on the other line as I believe it's much longer and more expensive.
