Any Word on 2016's?
I wish they would put in more 2nd row leg room, reprogram how the transmission shifts in stop and go traffic, add foldable arm rest in the middle of 2nd row bench, change door locks so peoples arms don't get pinched when it auto locks, add heated steering wheel option, softer steering wheel, removable rear headrests for better visibility, more comfortable front seats for larger people, larger sunroof.
Regarding your transmission, my 2013 shifted terribly between 1-2, it always felt like the truck was searching in the middle of the shift and the truck stumbled after the shift. My 2015 is 1000% better, so much so that now with 10k miles I find myself frequently thinking about how much better the shift points are and operation is. If yours isn't right have the dealer check it, perhaps there's an issue or a reflash that will help. Good luck.
Softer steering wheel? Mine is padded leather wrapped and pretty soft around its entire circumference, what model do you have?
Second row leg room is my biggest gripe. Seat should slide like most everything else on the market. Also, the front seat bottoms could be a bit longer. I'm 6'3 and they cut off circulation. My F150 seats are more comfortable. But I am loving the drivetrain. Also I have zero issues with MFT and sync. Did I say I love the drivetrain? We are getting at worst mid 16's with mid 17's being more common. Have seen mid 19's several times. And it has the power for sure.
I wish it had HID's. My F150 is like daylight.
75 SuperCab
02-10-2007 01:41 PM
taxidriver
18
06-18-2004 10:56 AM
