Holley / Motorcraft 4180c Choke Questions
Old 06-26-2015, 08:29 PM
Tkc432's Avatar
Tkc432
Tkc432 is offline
Just received my remanufactured Holley 4180c today. Opened it up and noticed right away that the choke thermostat on the new carb is different than on my old broken carb. I have a 1983 Ford F250 460 with the old style choke stove tube running to the choke and one wire running from the thermostat down to the alternator. The new choke thermostat has one pin style connector on it .. not the blade style that the old one had. It does have the Motorcraft stamp on it though. My questions are ..... is this a different choke setup or simply just a different connection pin? I would love to eliminate the choke stove since its rusted and JB Welded all the h*ll so is this new choke a full electric choke? And if it is a full electric choke how would I go about completing the unplanned conversion from hot air to full electric?
Confused again
Old 06-26-2015, 10:35 PM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
I can't answer all the questions. But, in my limited experience the Motorcraft units with a bullet-style connection are the 7 volt units, and usually say so. If it is a 7-volt unit it can be connected to the stator connection on the alternator, which gives about 7 volts when running. And, on a 2150 I was able to use that instead of the hot-air part of the choke.
Old 06-27-2015, 07:29 AM
Old Hickory's Avatar
Old Hickory
Old Hickory is offline
The bullet style connection is 7 volts and the power is supplied from the stator on the
alternator. The blade style hookup found on some truck engines is 12 volts. It won't
work with the bullet style.
Old 06-27-2015, 12:04 PM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
You know, you can always swap your old style choke element onto the new carb...
That said, if the choke wire is connected to the black/white stator connection of the alternator, it -is- getting "7V".
Maybe someone in the past decided that the $100 Motorcraft element was too expensive and they went with the cheaper Holley alternative.
Old 06-27-2015, 01:00 PM
LARIAT 85's Avatar
LARIAT 85
LARIAT 85 is offline
Old hickory is right. The 7 volt alternator connection is for Ford electric assist chokes ONLY. Fully electric chokes need to be hooked to 12 volts to work correctly.
The fully electric choke is more convenient, but the thermostatic "hot air" chokes work better because they work in lock step with the actual temperature of the engine.
79 ranger 4x4
03-14-2017 06:42 PM
dan240
12-31-2015 11:40 AM
muddyforeman
02-16-2005 07:10 PM
wizard1
03-15-2004 12:23 PM
Mustang6t7
02-02-2004 08:17 PM
Quick Reply: Holley / Motorcraft 4180c Choke Questions
