Swapping 9" Center Section - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Sign In
Register Forgot Password?
Old 06-26-2015, 02:43 PM
ZSK ZSK is offline
ZSK is gaining momentum as a positive member of FTE.
Like so many others, I want to get to a taller (numerically lower) gear ratio for the '56. Currently installed is a 9 inch from I think a '62 F100, I'll call this center section "A".
Years ago my dad parted out a 67 Galaxie and saved the center section from it. I'll call this center section "B".
Section "A" has a 4.10 ratio, 28 splines, and the fill hole located in the casting.
Section "B" has a 2.75 ratio, 31 splines, and no fill hole.
The 2.75 ratio would put the Lincoln Y Block right at 2300rpm at 65mph and leave some room to stretch it's legs still. It seems worth a shot to try the tall gears before purchasing a set of 3.00 or 3.25 to gauge a good cruising RPM.
With that in mind; what parts can I swap to make the two center sections play nice? If I disassemble both and try to fit 28 spline side gears into "B" I'll need to add a fill hole to my axle housing if that's an option. Is it possible to swap the "B" ring gear onto "A" carrier and then swap the pinion and retainer to "A" and avoid drilling a new hole in the axle housing? My measurement tools currently are only a set of calipers and feeler gauges, if buying a dial indicator to confirm backlash is good idea I'm not opposed to picking up one.
__________________
2007 Mountaineer
2007 F150
1956 F100
Old 06-26-2015, 04:03 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud ofALBUQ F-1 has much to be proud of
Edited: No carrier breaks on Ford 9"s, but carriers are different between 28 and 31 spline models. So the "B" pumpkin isn't going to work with your axles.
Do you have really short tires?
__________________
Ross
1952 F-1 Flat V8 3-on-the-tree MSD, Rochester 2G, Red's Headers
"Never attribute to malice that which is adequately explained by stupidity" -- Hanlon's Razor
Old 06-26-2015, 04:53 PM
ZSK ZSK is offline
Tires are 27" tall, not what I would call really short. Transmission is a T98 so there's no overdrive to lower the RPM's.
Old 06-26-2015, 06:02 PM
truckeemtnfords truckeemtnfords is offline
truckeemtnfords has a great reputation on FTE.truckeemtnfords has a great reputation on FTE.truckeemtnfords has a great reputation on FTE.truckeemtnfords has a great reputation on FTE.
You can probably pick a 9" pumpkin in the ratio you want for cheaper than screwing with what you have. If you have never done a 9" they can be a pain, as Jim (Underthebridgejim) can attest to. Easy work if you have done some. But once you split the carrier to do side gear work or anything you will find you need parts and then it only takes time and money from there. The ratios you are looking at are very common and should be found pretty cheaply.
You don't say what engine you have but I will go out a limb a suggest a 3.25 gear for the 27" tire.
__________________
Dave
2002 F-250 XLT 4x4 7.3 Auto CC LB
1955 F-100 302 T-5 9"
Old 06-26-2015, 08:42 PM
ZSK ZSK is offline
Engine is a 1953 Lincoln 317. I bumped the timing a bit, changed the distributor to the modern vaccuum advance, running rams horn exhaust manifolds and have a four-barrel 600cfm Edelbrock on top. An older shop manual states the output should be about 210hp@4000rpm and 305 ft/lb at 2300rpm and it feels like that is pretty spot on. I figure a cruise speed of 2200-2500 @ 65mph would be the best match.
Old 06-27-2015, 09:36 AM
ZSK ZSK is offline
Well, I grabbed a couple cold ones and some wrenches last night to see what would pan out.
Somehow the 4.10 gears had turned into 3.25, huh? Something isn't jiving there. Based on tire size, engine RPM, and road speed, even turning the tires and counting rotations everything pointed to a 4.10 ratio. Pulling the ring and pinion and counting teeth yielded 39/12 = 3.25 I'm still confused on that one.
Oh well, I had set out to see what would fit and still had a cold one. I ended up using section "A" as a base, swapped the ring gear and pinion with support from "B" to"A" and had to swap the yoke to stay with "A". The yoke from "B" was an inch longer than "A". At the end of the night I had a 2.75 geared 28 spline third member ready to install in the truck, now with a guard on the pinion support.
I've been inside a few other ford axles (7.5, 8.8, 9.75) but the 9 inch is the most basic I've been around. Adjusting the backlash by turning the large nuts on the side instead of carrier shims is great. Now to get it back in the truck...
Click the image to open in full size.
Old 06-28-2015, 11:50 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
31 spline axle shafts: Your '67 Galaxie 9" has a 9 3/8" ring gear.
9 vs 9 3/8: Only FIVE parts are the same: Housing gasket, pinion seal, pilot bearing retainer, one pinion bearing and race.
EVERYTHING else is different!
__________________
Bill / Retired Ford Parts Manager / SoCal Chapter Member / Part number research: 1928/2001 trucks & 1928/89 passenger cars.
2013 Escape FWD 2.0L Eco-Boost
Old 06-28-2015, 01:03 PM
ALBUQ F-1's Avatar
postin' fool
The picture shown above doesn't appear to be a 9-3/8, doesn't have the curved top rib.
__________________
Ross
Old 06-28-2015, 07:26 PM
OP said 1967 Galaxie with 31 spline axle shafts, but is it really a 1967?
If a 1966/72 Galaxie/LTD has 31 spline axle shafts, has 9 3/8" ring gear.
But, if it's a 1965 Galaxie/LTD with 31 spline axle shafts, has a 9" ring gear.
Bona fides:
__________________
Old 06-28-2015, 07:41 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to behold
Chuck Frank
Swapping in a used R&P can be a lesson in futility, unless extremely lucky in setting up the lash. Even a small change in the previous wear pattern can cause major howl and very short life. (BTDT have the T-shirt...) That's what makes the 9" drop out carrier so popular, just swap the entire carrier rather than just R&P.
__________________
Passionate about autocross racing!
1956 F100 Panel "GRACIE"
2007 Solstice GXP racer, the "KRAZED KANARY"
Third place finish 2009 SCCA National Championships
Old 06-29-2015, 03:11 PM
ZSK ZSK is offline
Bona fides:
It was/is most definitely a 9" ring gear and 31 spline side gears. I was too young in when we parted it out to remember the year, but I do remember getting the crap stung out of me when I bumped the football sized wasps nest under the dash while I was pulling interior trim. It's quite possible that it was a '65 as the section would leave us to believe.
Quote:
I went through that with my Ford Ranger that I had. Had a set of 4.10's swapped in and must have gotten lucky. Fingers crossed for this time around also.
__________________
2007 Mountaineer
2007 F150
1956 F100
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
