Anyone running 20 inch LT tires?
I have a 2013 F150 screw 4x4. Would like to replace the factory Pirelli's with LT load range E tires. Not looking for crazy off road tires. All terrain or highway all seasons would be fine.
I frequently pull a 24ft enclosed trailer with a vintage mustang (total trailer weight is a bit north of 8K lbs) and believe the LT tires would give me a bit more stability.
It doesn't look like there are many, if any, options in the factory 275/55 20 size.
If you are running 20 inch LT tires, I would be interested to know what size/brand/model you have.
Thanks
Thanks
I have a 2013 F150 and recently installed Toyo Open Country AT2 tires. 20" LT285/55R20 would be close to your stock tires. I however went with LT275/65R20. They look good, have a warranty, limited, but a warranty and seem to have good reviews. Put on stock Platnium 20" rims, no rubbing. I installed a 1.5" Auto Spring Front Level for appearance, looks good.
Check your spare, I bet it is a tire on an 18" rim. On my F150, it came with Pirelli Scorpion P275/55/R20's. I traded them for 18" Michelin P275/65/R60's. My spare is a Goodyear Wrangler AT/S LT275/65R18. So I replaced the four on the ground with the same. 18" rims are stock on my truck. 20" rims are an upgrade.
Dealership tried to tell me that 20" rims are stock and that the Goodyear Wrangler AT/s is the spare because it fits in the spare tire space. ??? The dimensions of the Goodyear Wrangler AT/s LT275/65 R18 is almost identical to the P275/55/R20 option.
stebab
1999 to 2016 Super Duty
20
12-29-2010 10:28 AM
