Ford econoline e350 RV overheating on traffic
Hi I have a 1990 Ford e350 RV which overheats in traffic but when just moving on freeways temp is fine. I've replaced the radiator the fan clutch and water pump and even removed the thermostat. Still issue persist. My mechanic did a test of engine block test and said no problem with head gasket leaks. I don't know if the radiator is big enough? The radiator shop said it is the same that I had which is a 4 core. Does anybody know the correct coolant capacity for these radiator? or any other suggestions to why the temp is going up on traffic only?
Ford econoline e 350 with 7.5 engine 8 cyclinder
Thanks,
Thanks,
on
I put 560 miles on an 89' this weekend and it ran on the "L" of normal the whole time. Is your cap releasing coolant into the overflow reservoir? Not sure about the coolant level, but it should be at least 5 gallons. With the temp sensor being on top of the manifold, the level needs to be full to get a good reading. You may have a bad sensor, or a blocked passage somewhere.
Retarded timing will cause a motor to run hotter and produce the symptoms you describe ..
To answer your question about the cap releasing coolant it does but I don't have an overflow reservoir since the RV did not come with one and it is too tight in there to put one so it just goes to the ground.
on
How are you checking the exact temp? Yes it seems a little high, but I don't know how high is too high. The one I drove was a Marine buddy's, but it held the same temp and never blew the cap and let any into the overflow. His didn't have a reservoir either, and I just assumed it was missing. He had the overflow hose leading to a 1 gallon coolant jug sitting right behind the left headlight.
Sent from my iPad using IB AutoGroup
on
An infrared temp gun isn't going to give you an accurate reading of the cooling water. Reference temp, yes. I would not assume it is the temp of your water, which is more important than any other place in the motor to check.
Put a thermostat back in it. It's a myth that removing the thermostat will make an engine cool better. If your coolant is moving fast it will keep running hot.
on
If you point the temp gun to the return hose it will get you closer to a realistic temp. The stock sensor is mounted atop the intake manifold in a water jacket, which according to ford, was the best place.
If you removed your thermostat and put it back in without seeing a change, you have a blockage somewhere or a bad sensor.
If that thing runs a normal temp at highway speeds and gets hot in traffic, it sounds like you need to check your fan clutch. Did you do that?
