heater core, fan motor, resister . replacement??
79 f250 no A/c Non hi-output.
i am looking to buy the best quality replacement parts.
i see a lot of options.
I do not see a copper heater core tho.
from any ones experiences can you tell me where to get the good stuff ?
Do the Resisters even go bad? thanks
Did a google search for copper heater core and found these people. Don't know anything about them though.
https://www.radiatorexpress.com/prod...FZAvgQodglkA-Q
And yes, resistors do go bad. They are made with several loops of resistor wire and the wires can burn through and break.
They're easy to replace though.
Thanks men. I forgot about LMC. after seeing the schematic on there site. Looking at the parking brake set up on the frame where the front cable connects to the back cables.
its Shows a arm with a spring and a threaded rod for adjustment. on my 79 f250 is that what i should have? when i got the truck it does not have that set up?
any light on this subject would be helpful. thanks
Click on the link.
All thansk to ranger429: For anyone looking for a brass/copper core Advanced Auto part number 398304 is the correct one. It is also the same core that fits early, 68'ish mustangs. Laurel Mountain Mustang is where I bought mine from. Part number just in case it is needed in the future:
For A/C 18476-1A, for non A/C 18476-2
1973-79 BRONCO HEATER CORE - WITHOUT A/C - BRASS | Laurel Mountain Mustang
Also NAPA but makes sure and ask are they aluminum or copper?
Copper is what you want. Heater core, high output heater
C6OZ-18476-B
Antique Auto Supply, Arlington, TX (817) 275=2381
Wesley Obsolete Parts, Liberty, KY (606) 787-5293
Dennis Carpenter, Concord, NC also has 1 but they have it listed under C60Z-18476-B, the third digit is "zero" instead of the correct letter "O". (704) 786-8139
Additional C6OZ-18476-B heater core applications:
1966/70 Falcon w/o A/C / 1966/72 Fairlane/Torino w/o A/C / 1971/73 Mustang/Cougar w/o A/C
Heater core w/ factory A/C or hi-low comfort vent system
D3TZ-18476-A
Std Heater core
D3TZ-18476-C
C6OZ-18476-B
D3TZ-18476-A
Std Heater core
D3TZ-18476-C
C6OZ-18476-B .. Heater Core / Obsolete
1973/79 F100/350 & 1978/79 Bronco with High Output Heater.
1966/70 Falcon w/o A/C / 1966/76 Fairlane/Torino/Ranchero/Montego w/o A/C / 1971/73 Mustang/Cougar w/o A/C
1974/78 Cougar w/o A/C / 1977/78 LTD II (not an LTD!)/Ranchero/Thunderbird w/o A/C
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 1 = 800-476-9653.
WESLEY OBSOLETE PARTS in Liberty KY has 3 = 606-787-5293.
MATLOCK FORD in Franklin IN has 4 = 800-987-3673.
D3TZ-18476-A .. Heater Core-Use with factory installed Integral A/C or Hi/Lo Comfort Vent System / Obsolete
1973/79 F100/350 & 1978/79 Bronco.
DENNISON FORD in Bloomington IL has 1 = 800-322-9431.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201.
KAMA OBSOLETE PARTS in East Bethel MN has 1 = 763-434-0123.
D3TZ-18476-C .. Heater Core-Use without factory installed Integral A/C or Hi/Lo Comfort Vent System / Obsolete
No Ford Dealer or obsolete parts vendor has any.
Pic = 18476: Basic part number for heater cores, scroll down to see applications. 2nd entry from bottom of page: C6OZ-18476-B .. Hi Output 8" core.
Stroker 1976
12-28-2018 11:27 PM
Menroid
02-26-2004 09:45 PM
kevinstang2
01-22-2003 09:21 PM
