1969 360 to 460 swap
06-25-2015, 11:46 PM
on
I have a 1986 460, I want to swap the 460 into my 69, will this work? is there any sensors or anything I have to worry about? I know ill need a different bellhousing and motor mounts but any help will be appreciated!
06-26-2015, 12:02 AM
If it's fuel injected you'll need to either need to convert it back to carb, or wire up the truck to run the EFI engine.
The engine stands can be found in the later model dentside trucks.
06-26-2015, 05:40 AM
Hunter Nelson Welcome to
and the Bumpside Forum.
Fitment wise pretty direct as noted by 351, bell needs to be the flat top 7.5" bolt hole spread.
John
06-27-2015, 10:51 AM
You have to use the transmission that comes with a 460 if it's an automatic (C6). If you put the short tail shaft on it you can use the original trans mount, cross member and drive shaft. I did that swap in about 1980 and am still driving the truck.
03-29-2016, 02:21 PM
on
My 69 has a 360 & is a 3 on the tree, can I swap 360 out for a 460 but keep the 3 on the tree?
03-29-2016, 02:29 PM
460 manual swap
I have the correct bell housing and related parts to use a manual transmission for a 460. p m me if any one is interested.
03-30-2016, 01:57 PM
on
Ok thanks, I'll let you know
460-67-FORD
19
07-29-2017 02:01 PM
Johnfm4
12-07-2010 08:10 PM
gsalisbury
10-15-2006 08:34 AM
f1508404
Engine Swaps
11-04-2005 10:15 PM
Highboy70
03-04-2004 12:19 PM
