You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Tire time- I now have 265/75/R15 is 31x10.5x15 an exact replacement? I see tires I want- was told this is the matching spec. I have no lift mods on the Bronco. Are other size options available?
Dutch, the 10.50x31 is indeed a direct replacement for the 265x75. (265mm equals 10.5 in.) You 'might' be able to go up to an 11.50x32. This size will be 1/2 inch wider on each side (at the sidewall center), and 1/2 inch bigger at the tire radius. You can compare the clearances you have now, to see if a larger size will fit. A lot will depend on the wheel type you now have (7.5" wide Ford alloys???)
10.50's are a good compromise. That's what I now have on my Bronco.
__________________
00 Explorer Sport 4x2, 4.0 ohv, 5R55E, 3.55 diff
Good, thanks... I have stock Ford rims , yes alloy but as to 7.5" I guess? Another post in the Bronco forum said the 10.50 is actually not as tall as the 265, said he did a side by side compare. I dont think the 32 will work I was looking at the clearance ,etc and the from well (down) near the black plastic portionof the bumper is maybe, may-be 1/2".
If it's a 4wd truck, 32/11.5s will fit just fine, but they will rub on the radius arm (those 31s might too). Not a big deal, just don't turn the wheel all the way.
