Shop Repair Manual
ALLDATA - OEM Auto Repair Information for Professionals ?
EXCLUSIVE ONLINE PRICING!
ALLDATA Repair S3000(New customers only. 1 computer access point)
$169.00 PER MONTH
Add to cart
ALLDATA Collision S3500(New customers only. 1 computer access point)
$209.00 PER MONTH
Add to cart
ALLDATA Collision S3500 Estimate Integration $50.00 PER MONTH
Add to cart
ALLDATA Manage Elite $105.00 PER MONTH
Add to cart
ALLDATA Training Garage Individual VersionOne year subscription for one individual
$299.00 ONE TIME
Add to cart
ALLDATA Training Garage Enterprise VersionOne year subscription for up to 10 users per shop
$599.00 ONE TIME
Add to cart
ALLDATA Training Garage Enterprise Version 55Monthly subscription for up to 10 users per shop
$55.00 PER MONTH
Add to cart
Collision Essentials $235.00 PER MONTH ALLDATA Collision S3500 ALLDATA Collision S3500 Estimate Integration
Business Essentials (Elite) $235.00 PER MONTH
I like the expired dealership service DVDs. Just use a program like
RUNASDATE to deal with the date issue. That way your not having
to reset the computer date to use the DVDs. Here is a link to download it
BTW it's FREE. Don't get it from Cnet. They pack a lot of extra ad-ware in the download.
When you download from the programer it comes out clean.
RunAsDate - Run a program with the specified date/time
Sean
$169.00 PER MONTH
Add to cart
$209.00 PER MONTH
Add to cart
Add to cart
Add to cart
$299.00 ONE TIME
Add to cart
$599.00 ONE TIME
Add to cart
$55.00 PER MONTH
Add to cart
Sean
The following users liked this post:
If you can find the right DVD for the year you
want that would be the way I would go. I have a file
given to me by Creator that shows you how to make it
so you can copy the data from the DVD and put it on
the hard drive. Makes things really nice if you don't
have to swap in and out when you change years.
BTW this is the Ebay seller I use for the DVDs 5hunter
http://www.ebay.com/usr/5hunter?_trk...72.m2749.l2754
Sean
Sean
have to swap in and out when you change years.]
15_15=10.0~3~T:~stock\home.htm~2015 Service Information~October 2014
Works wonderfully. Sure makes looking up something a lot easier.
You went to more work then is needed.
You only need the TSO directory.
Then the edit to the tsobrowser ini file
Here is the edit info for the INI file
; volume types
; 0 - unkown
; 1 - fixed disk locations (with directory)
; 2 - unc share locations
; 3 - removeable media
; each installed volume has an entry in this section
; the name of the entry is the logical volume (like 92CAR)
; and tilda-separated values on the right are:
; version - a number/letter string,
; less than 8 characters, NO periods, trust me
; type - as described in the list above
; path - the physical path to the location where the volume.ini file resides
; the browser will use that instead of checking volume labels (since
; it is quite problematic with UNCs)
; home - the name of the home file which is used for that volume
; title - The title of the volume (human readable, it is used to tell one
; volume from another in the selector list).
Sean
; volume types
; 0 - unkown
Sean
; volume types
; 0 - unkown
Sean
; volume types
; 0 - unkown
Sean
it in the oven and not the pie.
But really I do like cooking. I don't use the science method. More along the art
lines. Bit of this, a splash of that and a OOPS I dumped the box in But you
like cayenne pepper in your chocolate pudding.
Speaking of puddings looks like I am going to be eating soft things. Broke
a molar today. Hard to keep the tongue away from it. Dam,dam,dam! Sharp.
Sean
I use one of the expired DVD's also and the Run As Date program. The only difference is, I made an ISO copy of the DVD and use the program to "mount" this ISO in an imaginary DVD drive. All I has to do is modify the tsobrowser ini file to point to this imaginary DVD drive once the Service DVD is installed.
I get to play with a new DVD to add to the group. I have been having to guess
on the 2005 stuff to some extant and now have the 04~05 disk to cover
the F-150 ~F-350 and the Ex.
Sean
wgm114
07-12-2004 10:36 PM
