04 f-250 6.0 No start and low ICP psi
Old 06-25-2015, 08:45 AM
Emilio2496's Avatar
Emilio2496
Emilio2496 is offline
7th Gear
Hey guys! I need some help. I have an 04 6.0. My truck was running perfect, no problems. I start my truck, it started idealing rough for a couple seconds then just died. After that it just kept cranking and no start. There are no codes, tried unplugging the ICP sensor and nothing. Checked the fuel filter and its filling up with fuel before cranking. Oil is at a good level. FICM is reading 46.5-47.5 before cranking. Checked the ICP Psi I'm only building 11psi and HPOP was replaced in October.
Old 06-25-2015, 10:00 AM
WatsonR's Avatar
WatsonR
WatsonR is offline
time for an air test and if no leaks (STC fitting upgraded, dummy plugs and stand pipe?) the HPOP has probably failed. Wouldn't be the first to have a failed HPOP, some fail even when new... read a post here, three in a row before a good one.
Pull the IPR valve and check the screen, that would be the first step for me.
Old 06-25-2015, 03:12 PM
Emilio2496's Avatar
Emilio2496
7th Gear
Well at least the HPOP is under warranty but I'll still have to pay for labor which is bull***** because I just dropped over 4k in October on that and some other things. I'm gonna try the ipr valve next. If the screen is damaged is that a given that it's the ipr valve?
Old 06-25-2015, 03:26 PM
WatsonR's Avatar
WatsonR
WatsonR is offline
its a given that it may not be working correctly. IF the screen is damaged or plastic missing or the o-ring is damaged, replace it and try again. Those missing parts may be inside the HPOP... but try the IPR first. It doesn't run now, your not going to hurt it anymore by doing the IPR check/replace. Don't just go buy one either, check it first... and you need the special socket to get it off.
Did they upgrade the STC fitting, stand pipe and dummy plugs when you had the HPOP done? If the IPR is fine, then do an air test to confirm the HPOP, don't forget to command the IPR shut during the test so it doesn't give a false positive.
Old 06-26-2015, 10:44 AM
Emilio2496's Avatar
Emilio2496
7th Gear
Okay I will try and get it off this weekend. I thought the 04 didn't have have STC fitting problem only 05-07? I'll check the paperwork to see if they replaced those. I'll update the thread if I find anything else. Thanks!
Old 06-26-2015, 10:47 AM
WatsonR's Avatar
WatsonR
WatsonR is offline
depends on the build dates, if it's a late 04, then you have a STC fittings.
Old 06-26-2015, 11:00 AM
Emilio2496's Avatar
Emilio2496
7th Gear
My truck was built in 05/04
Old 06-26-2015, 11:18 AM
WatsonR's Avatar
WatsonR
WatsonR is offline
where is the ICP sensor located, on the passenger side valve cover?
Old 06-26-2015, 11:19 AM
Emilio2496's Avatar
Emilio2496
7th Gear
Yes it is located on the passenger valve cover
Old 06-26-2015, 11:27 AM
WatsonR's Avatar
WatsonR
WatsonR is offline
then you have a late 04, has the STC fitting. Time for an air test.
Old 06-30-2015, 06:23 PM
Emilio2496's Avatar
Emilio2496
7th Gear
Finally got the ipr valve off and there is no tears in it just a couple pieces of stuff. It's even been updated to the reinforced screen. Now what😕
Old 06-30-2015, 11:47 PM
fordf150guy's Avatar
fordf150guy
fordf150guy is offline
Air test the high pressure oil system and listen for leaks. Bonus if you pull the valve covers because you can get a visual where the leak might be comin from. Pretty sure you don't have a stc fitting...those came on the 05's and up and easy to tell if you do or not by which cover you have on the oil pump. Oil pump not sticking threw the cover=no stc, pump sticking threw cover=stc. Sadly after that it could be the pump itself being a 04.
Old 08-23-2015, 01:08 PM
Dieseldoctorsllc's Avatar
Dieseldoctorsllc
Dieseldoctorsllc is offline
Sounds like a leak in high pressure system need 500psi to fire. Need tested
Old 08-23-2015, 01:13 PM
bismic's Avatar
bismic
bismic is online now
Received 2,449 Likes on 1,696 Posts
Well said - Only 05 and up w/ the troublesome STC fitting
westandr
07-13-2018 01:25 AM
Fxstxl
03-20-2015 06:36 AM
sixpoint0
02-18-2015 03:54 PM
cabloom300
12-26-2014 03:34 PM
hotrodw30
08-19-2009 06:31 AM
Quick Reply: 04 f-250 6.0 No start and low ICP psi
