Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.0L V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-30-2003, 07:46 AM
old_man_van264 old_man_van264 is offline
old_man_van264 is starting off with a positive reputation.
air intake modification
i have a 94 aerostar with the 3.0 and was wondering if there is a way to modify the air intake box, or if its possibly to put on a cone filter from idiot zone. i want to get some more air to thios engine cuase it seems to be choking. its not a serious problem, just kinda low on power. i also want to do some high flow exuast but that will come later. i kinda of want to do a clomplete cold air intake if anyone can give me some tipson custom building one. im not really sure if the ranger 3.0 and the aerostar 3.0 is the same engine but i hiope you guys xcan help.
__________________
its a van, no its a stereo, no its a living space, no its a van, no its batvan!
  #2 (permalink)
Old 07-30-2003, 09:37 AM
agelder agelder is offline
agelder is starting off with a positive reputation.
Ah-ha... another Aero guy. I have the 3.0L in my shortie, and have the same problem as you. The engine is identical to the one in the Ranger (although air boxes and other minor things may be different due to the engine being under the dash). I pulled the silencer cone out of my airbox (~2" round inlet to the box from the silencer = restriction, it's now closer to 3" square), and it helped a little on the top end. I'll probably make a new air tube as well (looks pretty restrictive as well) out of plastic but keep the airbox (maybe with a cone) as a heat shield.
__________________
Currently 2001 Explorer Sport 4X2 Auto Black/Grey - 100k & still kickin'
Formerly 1993 Ford Aerostar Sport 3.0 Auto 2wd Standard length - Light metallic blue/grey 2 tone - RIP Transmission after 160k.
  #3 (permalink)
Old 07-31-2003, 05:39 AM
thanks for your help. im gonna take out my silencer as soon as the sun comes up. see what that does.i also want to do a bolt on high flow muffler for some better sound. if you make a new air tube id like to hear about it. especially if it works well.
__________________
  #4 (permalink)
Old 08-20-2003, 10:15 PM
silvapain's Avatar
silvapain silvapain is offline
silvapain is starting off with a positive reputation.
I have a 97' taurus with the vulcan engine, and I took out the entire fender snorkle. just have the hole going into the filter box. I also took off the muffler completely, but kept the resonator. souds great and runs fast. Only problem is that it is backfiring when i hit the gas and then let off.
__________________
1997 Taurus GL 3.0L Vulcan
  #5 (permalink)
Old 08-21-2003, 01:17 PM
i took of my silencer and you were right, it does get better power on the high rpm range. and it sound better. thanks for the help. that will get me by till i get a custom cold air intake going
__________________
  #6 (permalink)
Old 08-21-2003, 02:36 PM
ha ha... gotta love free mods!
__________________
  #7 (permalink)
Old 08-24-2003, 01:56 AM
scott9050 scott9050 is offline
scott9050 is starting off with a positive reputation.
While you are at it, take a grinder and get rid of the air bridge in the MAF. That will complement nicely the changes upstream in the airbox.
__________________
1993 aerostar xlt extended 3.0
1990 AOD 5.0 mustang
best old time 13.65 at 104.57
  #8 (permalink)
Old 08-25-2003, 12:59 AM
silvapain's Avatar
I took the defletor tube out of my MAF, and now it idles rough when it first starts. After I rev the engine, it goes away. There is a posting on the forums here that will explain the pros and cons of that. I really didn't notice any gain in HP, either
__________________
  #9 (permalink)
Old 08-28-2003, 02:59 AM
Let it run a while. Mine did the same thing until the engine warmed up. It seems that the computer had to learn the difference. Now it runs great.
__________________
  #10 (permalink)
Old 08-28-2003, 04:10 AM
Hammy211 Hammy211 is offline
Hammy211 is starting off with a positive reputation.
A guy told me that the duratec 3.0 in my taurus had a stock CAI and that removing the intake silencer it would still be in the fenderwall hence still CAI. It is a 2002 taurus. Sound correct? I have the vulcun in my truck. It does not work this way I believe. I had thought of putting a ram intake in it but decided against it since I believe it is currently getting cold air. Can I remove the silencer on the vulcun and extend the filter box to still recieve cold air and expect performance gains from this. Where will the bottlenecks be after this mod.
__________________
2000 Mazda B3000 3.0L ffv V6
2002 Ford Taurus SEL 3.0L 24v
  #11 (permalink)
Old 08-28-2003, 11:06 PM
Quote:
Also, did you clean the wite in the MAF? I used contact cleaner from Radio Shack and it helped.
__________________
  #12 (permalink)
Old 09-02-2003, 07:52 AM
silvapain's Avatar
yeas, I did clean my MAF. I used electrical contact cleaner so to not damage the element. IT has been about a month now and it still idles rough at first. Will probably alweays be that way.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
