Want to upgrade Mirrors--Hitting a wall
Old 06-24-2015, 01:22 PM
sgtevmckay's Avatar
sgtevmckay
sgtevmckay is offline
Want to upgrade Mirrors--(UPDATED 3/19/2019)
I have a 1994 Econoline E250.
I recently bought a set of side mirrors that were listed to "match" my year /model of van....upon arrival, the mirrors are 4 post and original equipment is 3 post mount.
Original Amazon Purchase link: Amazon.com: Driver and Passenger Manual Towing Side-View Mirrors Replacement for Ford Van 7C2Z17683DA 7C2Z17682DA: Automotive
I love the mirrors, but as seen in the image below, there is no way to get these mirrors on.
I need a permanent towing mirror solution.
I would be willing to modify my van if at all possible to accommodate these mirrors, but would rather not without clear instructions, and sample images of this having already been done.
I have contacted several Auto parts store, online retailers, Mirror sellers, etc looking for an equivalent mirror for my 94 E-Series, but am coming up empty.
Can someone point me in the right direction, make a suggestion of where to look, or who to contact, for actual towing mirrors that would fit this year and model Van.
Or is there other alternatives I am missing???
Any and all help would be greatly appreciated
Thanks in advance
Old 06-24-2015, 04:51 PM
econolinemanor's Avatar
econolinemanor
econolinemanor is offline
That's a common problem....sort of, I was looking at new ones for mine and most listings would range from 92-up and some would say 92-02 and then 03-up. My 02 has 3 studs and I think Ford went to 4 studs in 03. Either way a lot of the Aftermarket part listings are wrong.......
Old 06-24-2015, 05:09 PM
tabijan's Avatar
tabijan
tabijan is offline
It might be easier to fit '03-up doors to go with those telescoping mirrors.
Sixto
93 E150 Chateau 5.8 191K miles
Old 06-24-2015, 07:54 PM
wiskeyVI's Avatar
wiskeyVI
wiskeyVI is offline
Can you remove a post to make them fit?
Old 06-24-2015, 09:39 PM
sgtevmckay's Avatar
sgtevmckay
I will take a closer look tomorrow.
At first glance it looked as though the metal is a single Aluminum piece, but will double check
Old 06-25-2015, 05:54 AM
JWA's Avatar
JWA
JWA is online now
Received 1,393 Likes on 1,102 Posts
Y'all listen up here..................
The 4 stud mounting mirrors and their matching doors first appeared beginning model year 2003. While its possible to cobble earlier doors to accommodate those larger-base mirrors given their weight and wind issues it would be far, far better swapping door shells of the proper year.
Most DIY salvage yards should have the proper doors complete for less than $150 each, you naturally doing all the removing etc. Of course this might necessitate having "new" doors painted to match the existing van color so that too needs to be a consideration.
I've done this sort of cobbling and was not happy with the finished results, most notably how they couldn't be mounted as securely as a proper fit would have yielded.
IF those mirrors are absolutely necessary swapping door shells is the best way to go.
Old 06-25-2015, 01:15 PM
sgtevmckay's Avatar
sgtevmckay
Thank you....this is the straight up answer I am always looking for.
Now? Is there other alternatives to consider???
Other extendable towing mirror makers?
Other mirrors (period)
I miss the old twin 4 inch (one standard 4 inch mirror and the 4inch fish-eye) on the white "C" Bracket, and I can not find a supplier for those.
Looking for more suggestions
Continued help is appreciated
Old 06-25-2015, 01:59 PM
tabijan's Avatar
tabijan
tabijan is offline
Old 06-28-2015, 08:51 AM
kountzecobra's Avatar
kountzecobra
kountzecobra is offline
I would change doors. These later model vans are getting to the wrecking yards now (our local you pull it yard has 2 vans 04-07 and doors are about $70 each)
Old 06-29-2015, 07:57 AM
JWA's Avatar
JWA
JWA is online now
Yep, yep and double yep on this ^^^ !
IMHO it makes no sense farting with trying to modify something when a simple and relatively cheap fix is just a few bolts away.
Old 07-07-2015, 04:41 PM
WarrensE350's Avatar
WarrensE350
WarrensE350 is offline
At least you don't have my mirrors and desire an upgrade! Mine are even turned in and inverted so they don't stick out so far.
Old 07-07-2015, 04:49 PM
wiskeyVI's Avatar
wiskeyVI
wiskeyVI is offline
DUDE-
I SO remember wanting those mirrors for my old Ford F250!!!!!
Old 07-07-2015, 07:54 PM
blageurt's Avatar
blageurt
blageurt is offline
I have a brand new set of those still in the Box.........FORD ones....
Old 07-08-2015, 05:50 AM
JWA's Avatar
JWA
JWA is online now
Well, cripes---since we're sharing our unused or excess inventory of Ford E-Series parts.......
I have an unused set of dual element power mirrors fitting 2003 and later doors. Any interest just ask---they'll go cheap as they're just not used and no use in the near future foreseen either.
Old 07-08-2015, 08:07 AM
WarrensE350
Actually I'd like a brand new set of what I have, that would be my 'upgrade' of choice. No way to cheaply modify my current doors for new style mirrors or paint a pair of doors to match the current scheme.
Sorry to threadjack you there, OP!
Quick Reply: Want to upgrade Mirrors--Hitting a wall
