Aluminum front winch bumper worth it?
Hey all. I just bought a 95 F-150 4.6IL6 M5OD standard cab long box 4x4 for a Minnesota work truck. Set up as a "heavy half-ton". Would like to add a steel ladder rack and front winch bumper to pull docks out of the water, have confidence if I need help on the low maintained forest/logging roads, help ditched folks, etc. Should I be worried about a heavy steel plate winch bumper (do not need super duty bumper like Ranch Hand) on this truck with regards to brake wear, front end parts, handling? Aluminum is available but so much more expensive. What do you think? Thanks.
I thought about the receiver type but I want it with me the whole time and I do not want a tool box so I can have full use of the box. THe hidden is how I want to go but wonder if the material (steel/aluminum) makes a difference on the performance and longterm wear on the front end parts/brakes. I got some good info so far from you all, thanks. I didn't think about the camber being changed with extra weight...makes sense. So, whatever I do, I need to realign after I put it on, right?
https://www.ford-trucks.com/forums/1...l#post14264383
1995 F-150XL 4.6IL6EFI M5OD 4x4 130K Recently Idaho truck now in Minnesota.
Here is what I'm working with. I was also wondering, since I will go with a steel front winch bumper/lights set up, should I counter the front weight with a heavier duty rear bumper too for winter and freeway speed driving balance? I'm thinking steel ladder rack so my work/play truck will be complete. I haul lumber, tools, woodchips, dirt etc. for my various home and small real estate business projects and want to play a little in the forest roads in northern Minnesota where the cabin is. Thanks for all the great tips here fellas!
87f150mudder
09-04-2013 05:19 AM
14&Ford
11-20-2010 09:57 PM
donniezyea
11-09-2010 10:32 PM
maverick1701
06-17-2008 01:54 AM
NavFlyer
09-24-2002 01:48 AM
