Stock sticks and banks 1.0 egts. - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 06-24-2015, 10:29 AM
Ezalycasaid's Avatar
Ezalycasaid Ezalycasaid is offline
Ezalycasaid is starting off with a positive reputation.
I have stock sticks and a 3" down pipe. I found a banks 1.0 turbo housing for cheap. Are my egts going to go way up with the 1.0 housing? I dont have room for an intercooler after the 6.0 trans cooler install. Would I have to install an intercooler with the 1.0 housing? Also what can of worms would I be opening with the 1.0 housing? thanks.
Old 06-24-2015, 02:00 PM
cowmilker08's Avatar
cowmilker08 cowmilker08 is offline
cowmilker08 has a good reputation on FTE.cowmilker08 has a good reputation on FTE.cowmilker08 has a good reputation on FTE.
I'm confused, do you or do you not have an intercooler?
Old 06-24-2015, 02:56 PM
Quote:
Ok fixed it. Sorry I do NOT have an intercooler. Just the 6.0 trans cooler.
Old 06-26-2015, 01:43 PM
ved0303's Avatar
ved0303 ved0303 is offline
ved0303 is starting off with a positive reputation.
I would definitely get an EGT gauge if you don't have one already, whether you do the 1.0 or not. That way you always know exactly where your temps are at and whether or not you need to ease off. Either way, I think your EGTs will be fine with the 1.0 as long as you aren't hammering on it constantly with a hot tune.
7.3 intercooler options nossliw 1994.5 - 1997 7.3L Power Stroke Diesel 66 09-02-2016 11:48 AM
Billet compressor wheel and quick spool on stock sticks Ezalycasaid 1994.5 - 1997 7.3L Power Stroke Diesel 31 03-29-2016 10:53 AM
Questions on towing, no intercooler Dial911 1994.5 - 1997 7.3L Power Stroke Diesel 23 03-11-2013 10:14 AM
Towing with Van Turbo 1.15 bigpowerstroke 1999 - 2003 7.3L Power Stroke Diesel 45 09-02-2010 05:56 PM
Slightly lower EGT's....turbo housing? RocknXJ 1994.5 - 1997 7.3L Power Stroke Diesel 20 03-05-2007 11:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
