AC Charging
AC Charging
My 1990 f 150 had no AC since I got the truck. Mechanics said $200 - $400 to change to R134
And replace high pressure lines. Compressor seems to work ok. I had a crazy idea of finding a nameless refrigerant on the Internet and charging it myself to see if it might just need to be charged. I attempted to vacuum out system and added charge and it actually blows cold air now😀 my fuse blew since it was a 15 amp should be 30amp but all went as was supposed to as soon as I started filling system compressor engaged. Is it normal for the compressor to go off and on often it should it stay on longer if Ac is on full?
Thanks that really helps!
Received 3,090 Likes
on
on
r 12 and see if it works. And a couple weeks later it's still holding up.
Shush that talk and don't let my 89 Ranger hear such things! I recharged the system with 134A eight years ago and didn't change anything, just vacuumed and recharged with 134A.... I'm not recommending this but I can still run the fan on low and freeze myself out of the truck and only lose 1/4 can a year. I do have a spare bigger compressor pump sitting on my shop shelf anticipating it's failure and did have the part numbers for full the conversion but it's still blowing ice cold air.
on
on
