5.4 Temp gauge issue?
1997 E-350 5.4L. Starts and run okay. Not boiling over or leaking.Temp gauge needle is up in the red zone once up to temp. Scan gauge indicates ECT 220 - 225. No CEL or codes present. I am trying to figure out if I have an overheating issue or a gauge/sensor issue. I'm assuming that the scan gauge reads the ECT from the same sending unit that the dash gauge uses, so if the sending unit were bad, I wouldn't get a temp reading on the scan gauge, no? 220 seems to be on the high side of normal, but I wouldn't think that would peg the gauge. I'm wondering what temps correlate to the dash gauge. Thoughts?
I have a similar problem. My temp will spike to the max and the "check gauges" message will appear. If I pull over - shut down - restart immediately - the gauge goes back to normal. Motor does not appear to be hot. Seems like a bad coolant temp sensor to me. Garage said it would be almost $200 to fix it. Anyone out there know what it takes to replace the sensor? Where is it located? Under the intake manifold?
jlamb02910
05-13-2018 10:57 AM
machinist91
10-01-2013 09:56 PM
