1957 f 100 or f 250?
Hey
I found the VIN on my truck,it matches the title. Its a 1957 f 100, 2 wheel drive, according to the vin. But it has 8 bolt wheels,floating axle rear end,and the second set of over load leaf springs. There is a badge on the hood that says f 100. I'm replacing all the drive train so its not a big deal but was wondering if you guys had seen anything like that. Until I found the frame number I thought I might have the wrong title for the truck. thanks for any info. Mike
Hey
I found the VIN on my truck,it matches the title. Its a 1957 F100, 2 wheel drive, according to the vin.
But it has 8 bolt wheels, floating axle rear end, and the second set of over load leaf springs. There is a badge on the hood that says f 100.
All 1957/58's are 2WD, because factory installed 4WD wasn't introduced until 1959.
But, in 1959/60, the series code does not decode to 2WD or 4WD .. all it decodes to is F100 or F250. The MODEL code stamped on the Warranty Plate defines 2WD from 4WD
tripleframe
05-09-2016 12:26 PM
SuperDoody
08-26-2007 01:47 PM
