Door lock question
Door lock question
I do not have any keys for the door lock on the 59 and the ignition lock does not match. I bought a door/ignition set from LMC.
When I took the access plate off, I do not see anythin connecting the log to the latch mechanism. Does anyone parts diagram to show what I am missing?
Sorry, I forgot to take pictures, I will do that tomorrow.
1957/60 F100/1100:
2) B5A-7021971-A .. Door Lock Actuating Lever-attaches to door lock cylinder / Additional applications: 1955/56 Ford Passenger Cars / Obsolete
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
WESLEY OBSOLETE PARTS in Liberty KY has 1 = 606-787-5293.
OBSOLETE RELIABLE PARTS in Nashville GA has 16 = 229-686-5101.
2) B7A-7022075-A .. Door Lock Cylinder Retaining Spring-attaches to actuating lever / Additional applications: 1957/58 Ford Passenger Cars & 1955/60 Thunderbird / Obsolete
OBSOLETE RELIABLE PARTS has 1.
GRIESEL MOTOR CO. in Okarche OK has 1 = 405-263-7242.
NORTZ & VIRKLER FORD in Lowville NY has 9 = 315-376-6594.
These 2 parts are not shown in truck pic (upper).
EDIT: Look at 2nd pic (lower - 1955/57 Thunderbird). The actuating lever is shown as 21968 .. the spring as 22075
When you bought a genuine Ford door & ignition lock set, these parts were included.
Actuator shown as 21968 .. spring as 22075
Both the T-B actuator and its spring are the same as 1957/60 F100/1100.
Ok, I gave up trying to figure out how to separate the door lever actuator and spring from the end of the door cylinder lock and took it to a local locksmith who took about 2 seconds to separate the two parts.
The spring holds the actuator to the end of the cylinder lock. To free the actuator, pull up on the spring end opposite the actuator and slide the actuator out of its socket. The actuator will slide out only in one direction. If you hold the door lock in the orientation that it is installed in the door the actuator is released by pulling upward on the actuator as you pull the end of the spring up and away from you.
daveengelson
11-06-2017 02:21 PM
qman
15
09-08-2017 06:12 PM
