2004 e-150 chateau
Old 06-21-2015, 04:55 PM
raysxb's Avatar
raysxb
raysxb is offline
2004 e-150 chateau
Got a question. I recently bought a 2004 e150 chateau. I don't recall it happening initially, but now if I'm excellerating, the a.c. stops blowing until about 30 seconds into easing off the gas. I dont recall it ever doing it in the beginning. I noticed it initially while going over a bridge. Now it seems like it all the time. When it does it, it's like it's blowing hot air toward the floor, nothing blows thru the vents, then you feel the cold air kick in at your legs then it works it way back up to the dash. Any ideas? Then the kids told me that it will stay blowing hot air on the floor in the back area. I actually have to turn it off wait and turn it back on. Eventually it works and blows cold again.
Anyone ever have this happen? Is this normal?
Old 06-22-2015, 11:19 AM
GreeVan's Avatar
GreeVan
GreeVan is offline
The rear ac/heater unit is as high tech as a stone axe. If the front control are in AC or vent, it will blow cold air from the roof vents. If the front is on defrost or foot outlet, it will blow hot air on the rear floor vents.
If this is not the issue, you may have vacuum leak since you have issues when the engine is under load. Look for threads on how to fix it, there are very good topics here.
Old 06-22-2015, 12:33 PM
tabijan's Avatar
tabijan
tabijan is online now
No, it's not normal. x2 on insufficient vacuum to or within the AC controls. Probably a loose or tired vacuum fitting somewhere.
Sixto
93 E150 Chateau 5.8 191K miles
Old 06-22-2015, 12:37 PM
vettex2's Avatar
vettex2
vettex2 is offline
thuff1988
11-16-2018 04:33 AM
phillips91
05-23-2013 03:04 PM
Kountryguy
1999 to 2016 Super Duty
04-23-2009 05:17 PM
swenson
1978 - 1996 Big Bronco
07-31-2002 02:12 PM
killer4x4
11-06-2001 02:54 AM
Quick Reply: 2004 e-150 chateau
