Fuel not getting from pump to carb - '68 F100
I replaced the fuel pump and both fuels lines on my truck but cannot get fuel to enter the carburetor. Does anyone know how the resolve this?
A little info: the truck is a 1968 F100. It's a 6.4L 490. I replaced the old fuel pump with a new Carter fuel pump. The carburetor is a double barrel Edelbrock.
Thanks for any advice you have.
An in-cab tank, right? It's gravity fed after having a siphoning effect. Ya might have lost the prime.
Can you clarify what you mean by "both fuel lines".. Tank to pump and pump to carb?
Try this.... disconnect the line at the carb and put some fuel into the line. All the better if you can fill it up. The pump might needs some thing to push against. Reconnect and retry.
Btw, parts can be bad regardless if it is new.
Is that bamboo stick E85 compliant, ISO 6000, gluten-free yadda yadda?
Orich brings up a good point, there is an oft-overlooked short hank of (by now) fossilized rubber hose underneath the cab that should be replaced., may be cracked or sucking air. This is a convenient spot to tie in an electric fuel pump, filter, drain or shutoff, etc. Maybe while old hose removed it would be convenient to blow out the lines fore and aft with compressed air. There should be strong pressure out of fuel line (3-5 psi say) and approx. one pint in under 30 seconds.
on
Orich
on
Yes amigo, that is a bamboo stick, with nuclear grade magic marker. Impervious to all known nonsense, and compliant to common sense, a rare earth commodity these days.
I found an old Bendix, magnetic fuel pump, off a Cessna, on Evilbay, for $70... I figure if it is good enough for aviation certification, its good enough for my Highboy. I see they are used on Porsche too. Guess they went out of the fuel pump biz, as they were too good.. My first one lasted 40 years, until some bandito liked it better than I did...
If your lines are clear, like Orich says, and your pump works, then there should not be a problem...?? Hope you find it..
Baja
Baja
