mpg difference between 3.73 and 4.30
I have done some crazy research and calculations (Excel) in regards to which gear ratio to get.
I have realized that the 350 Dually utilizes the shortest tires available on the Super duty line. So in effect lowering the ratio more.
Take a look at the different tire sizes to gear ratio to RPM. Tire sizes are calculated not actual.
Yes there is extra drag with the extra rear wheels, but I believe the shorter tire is hindering the mileage unloaded.
This spreadsheet helped me change my mind from getting the 4.30 gears to 3.73.
An interesting fact I found also is that the normal 1:1 (4th) is not 1:1 it's 1.15 :1, so in 4th gear a 3.73 ratio is actually 4.29.
I can post a dropbox link to the spreadsheet if anyone would like it. What are your thoughts ?
ZooDad
ZooDad
the second row has the slash & dash in the wrong place
and the two dually +1.5 and +2.5 have the wrong diameter (70?)
Received 3,988 Likes
on
ALL things being equal, if you increased the height of the tire at the same speed you would be a fewer rpm, theoretically you would see an resultant increase in mpg...because the engine is turning fewer rpm, in other words not breathing as hard.
Now the world becomes very complex and you get into torque and Hp curves, application of power in order to overcome rolling resistance and wind etc etc etc.
In theory you could see a 13% mpg increase (4.30 vs 3.73) which would translate out into about 1 mpg, in reality unless you made a long trip chances are the end of month fuel bill would come out about the same or so close you would not the difference.
Of course taller tires will weigh more, thus more effort to spin up.
Based upon my observations of the '15> 6.7 I think a 4.10 would be the best choice.
Don,
I am in total agreement on the 4.10 ratio for the dually. Back in 99 it was the Dually option.
I also found out my analog speedo needle is 3 mph fast..., but the ECM is right on the money with the GPS. I just can't figure out how I can be off by 10%. I get a few on either side, but 10%.... My OCD is kicking in. When I have the wheels off I will most likely count rotations. Maybe Ford slipped in a set of 3.55.
When someone has a free moment can you confirm RPM at 60, 65 and 70 in 6th gear please. Reading off the ECM is preferable.
So if I end up doing my tires I will be spinning about 1700 @ 65.
Paso,
Can you draw a tape on your rears unloaded overall and approximate center of hub (radius). Thanks
Thanks to everyone.
Keith
Paso,
Thanks to everyone.
Keith
mostly insignificant difference. The 4.30 might get better mileage if/when towing heavy loads at lower speeds/rpms, but again, not really enough to matter in my opinion unless your planning to max out towing capacity and tow most of the time. Id go for 3.73 given those choices. personally i have 3.55 but i only tow around 9000 pounds less than half of the miles i drive. My unloaded average is pretty well right on 15.5mpg if i dont reset the meter for a few hundred to a few thousand miles, If i do reset it I get 17-19 on flat roads no wind at 70mph, 22-24mpg at 55mph flat roads no wind(but i never go that slow for long, speed limit on all highways is 65 in my state). I get 10-11mpg average towing 9000 pound 5th wheel going 70mph for 1500 miles from ND to NV through the rockies. Worst ive seen is 7mpg going 70 against a 40mph wind and best is 13mpg going 70 with flat road no wind.
You guys and your gear ratios lol.
IMO with the gazillion gears in the tranny there is no reason to go for the lowest gear possible anymore. No one said you have to use top gear when towing.
My 3.31's get the same mpg when towing as others have mentioned BUT my unloaded is much better than others.
#28
#29
I agree with you Don...
Unless you need to pull at max tow ratings, I don't see getting a 4.30 rear gear. Especially if your concern is MPG running empty on the highway at highway speeds. I've never heard of anyone going to higher number rear gear for the mileage. Better performance/get up and go off the line and towing capacity, yes...
#30
My '11 F 350 w/3.73 gears got good mpg, good performance (I carry a camper in the bed that weighs in about 5500 lbs) and sometimes pull a trailer also will provide improved mpg and performance with 4:10 gears than either 3:73 or 4:30
