Hey guys I'm getting a code 62 the torque converter has been replaced before the truck sat for two years when I clear the code it is slipping slight but when in limp mode no slips at all curious to what I should do I already replaced my tps set correct voltage just getting a code 62 after driving for 5 miles od starts flashing any ideas what to check?
Check the period and comma key on your keyboard for proper operation. Press and quickly release the key and give us the results of what happens on your screen.
Haha funny I've read many of your threads and I'm hoping it's the harness when I cleaned it redneck style I got the code to stay off for about 10 miles I'm going to inspect it more tonight need my baby back haha also now when I clear the code and turn it on it comes on instantly without even putting it into gear
62 shouldn't set until the TECA senses a slip iirc around 4 or 5 times.so having it just pop up without even being in gear,after you cleared the codes seems very odd.like a bad TECA type odd.
