1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Why go F-250 when I can do F-350 for a tiny bit more $?
Old 06-29-2015, 12:27 PM
ligito's Avatar
ligito
ligito is offline
** Towing capability not available for consumer rentals.
  #32
Old 06-29-2015, 04:48 PM
xr7gt390's Avatar
xr7gt390
xr7gt390 is offline
If you can get past the issues, they have limited locations & they rent to businesses. It might be a good way to go.
  #33
Old 07-04-2015, 10:19 AM
Agro's Avatar
Agro
Agro is offline
Problem solved.
https://www.dropbox.com/s/9q40x9j5ok...74227.jpg?dl=0
  #34
Old 07-04-2015, 12:36 PM
Strokin-A-2010's Avatar
Strokin-A-2010
Strokin-A-2010 is offline
Originally Posted by redford
Clearance lights are required on vehicles over 10,000 GVWR.
This is not true. My 2010 F350 was 11,500 GVWR and it didn't come with them.
  #35
Old 07-04-2015, 03:13 PM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
OK, I'm done with the conjecture. It almost certainly varies by state, but for those of us in Texas the ultimate answers are all found here:
TRANSPORTATION CODE CHAPTER 547. VEHICLE EQUIPMENT
Sec. 547.352. ADDITIONAL LIGHTING EQUIPMENT REQUIREMENTS. In addition to other equipment required by this chapter:
(1) a bus, truck, trailer, or semitrailer that is at least 80 inches wide shall be equipped with:
_____(A) two clearance lamps on the front, one at each side;
_____(B) two clearance lamps on the rear, one at each side; aka the yellow/red lights on dually fenders
_____(C) four side marker lamps, one on each side at or near the front and one on each side at or near the rear;
_____(D) four reflectors, one on each side at or near the front and one on each side at or near the rear; and
_____(E) hazard lamps that meet the requirements of Section 547.331;
(6) a vehicle at least 80 inches wide may be equipped with:
_____(A) not more than three front identification lamps without glare; and aka the tripple light under the tailgate
_____(B) not more than three rear identification lamps without glare.
  #36
Old 07-04-2015, 07:26 PM
msgtord's Avatar
msgtord
msgtord is offline
Same rules in Arizona.
  #37
Old 07-05-2015, 05:19 PM
xr7gt390's Avatar
xr7gt390
xr7gt390 is offline
Originally Posted by Agro
So is that your new truck? Looks nice.
  #38
Old 07-05-2015, 08:51 PM
Agro's Avatar
Agro
Agro is offline
Yep, thanks. F-250, 3.55 diff, Lariat ultimate pkg, tail gate step, navigation, i dunno tons of crap, the original window sticker was $62,800 so its pretty fully loaded, albeit 2012, not 2016... It is in excellent shape, but not brand new, so I wont be as **** over trying to ensure nobody touches it, breaths on it, or even looks at it wrong.
  #39
Old 07-05-2015, 09:15 PM
bigredtruckmi's Avatar
bigredtruckmi
bigredtruckmi is offline
Pink one come along also?
  #40
Old 07-05-2015, 09:35 PM
Agro's Avatar
Agro
Agro is offline
haha! The pink one is my pride and joy. The payload that carries is by far the most critical
pic linked rather than dropbox below.
  #41
Old 07-06-2015, 09:30 AM
speakerfritz's Avatar
speakerfritz
speakerfritz is online now
check your local laws.
in NYC, f-250 needs an exception to get pass plates and with no pass plates you can not park in residentual areas as well as go on parkways.
an f-350, has the same exceptions rules, but in addition, the close to 7000lbs empty weight will put you over the max for parkways.
to get an exception , for pass plates, there are various use options such as a camper top.
fyi, f-150 may slides in under the wire of 5500lbs. no plate hassles, no parkway hassles, and an f-150 has a pretty respectable load rating if you can get by with a lighter duty truck.
  #42
Old 08-06-2015, 06:23 AM
drcox79's Avatar
drcox79
drcox79 is offline
Originally Posted by mbutts
Because clearance lights are cool!
Seriously the only reason I put mine on!
  #43
Old 08-06-2015, 10:33 AM
SWV10's Avatar
SWV10
SWV10 is offline
It use to be the Dealers here always had clearance lights on all of the F350s on there lots but not anymore. Seems allot of Buyers don't care for the clearance lights so anymore it is seldom you can find them on a New F350 SRW.
I went with the F350 over the F250, the same truck between the two was only a difference of $700 and yes the F350 will have Clearance lights.
Here in NM the registration is a little higher for a F350 Vs a F250 but nothing to get in a uproar over.
SnowPlowDriver
03-07-2017 03:49 PM
BigBri BigBri
6.7L Power Stroke Diesel
10-22-2010 04:54 PM
68rs327
12-09-2009 06:48 PM
KSims1868
23
06-22-2005 06:12 AM
Quick Reply: Why go F-250 when I can do F-350 for a tiny bit more $?
