P01451 and P0353 - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign In
Register Forgot Password?
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
P01451 and P0353
Old 06-18-2015, 10:26 PM
Dalluge103 Dalluge103 is offline
Dalluge103 is starting off with a positive reputation.
P01451 and P0353
My trucks throwing 2 codes after traveling at low speeds and getting pretty warm. Drove it home after it cooled down. P1451 with is the EVAP Cannister Vent solenoid and P0353 which is Cylinder 3 Primary/Secondary Ckt. I keep getting told these are not connected but im not sure I believe that. Ive replaced the coil with 2 of my stock coils already with no luck, ive replaced the spark plug as well.
Old 06-19-2015, 10:24 AM
Bluegrass 7 Bluegrass 7 is online now
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
The codes are not 'directly' related because the systems are way different.
However a 353 code and replacement coil that did not clear the code suggest another possible problem that could have caused the 1451 code.
Follow closely because there maybe two or more issues that has resulted.
1. The 353 code is a failure of the coil circuit that caused missing spark for cylinder 3. This can be caused by coil failure, harness or it's connector failure, or the computer driver for that cylinder has failed.
2. If you drove long enough with cylinder 3 out of spark, that cylinder kept feeding unburnt gas to the cats on the passenger side. This could have caused the cats to burn that gas to temps well over 1000 degrees. It could have melted the cats and the rear Ox sensor.
3. The very high temps in the surrounding area of the cats could have burned the harness that has Evap leads, transmission control leads and Ox sensor leads in the bundle.
You need to have a look at all these area first to be sure of what the conditions are.
First thing to do is get cylinder 3 back before any other repairs are made or the same things can occur over again to other repairs made first.
If the computer coil driver is the cause of 353, the computer has to be replaced, programmed and PATS/keys programmed.
If all the above has taken place, your repair bill will get expensive.
I wish you the best outcome and hope it does not go to that level of repairs..
Let us know how it goes.
Similar Threads
2002 RANGER CODES P0353, P0302, P0306 Mary Smith Harner Ranger & B-Series 12 09-10-2014 03:50 PM
06 5.4 Cylinder 3 misfire P0353 johngeorge Expedition & Navigator 14 10-28-2013 08:42 PM
2006 F150, 4.6 V8, OBD Error P0302 Tony Berry 2004 - 2008 F150 11 03-09-2012 03:13 PM
P0353 Ingnition Coil C Problem sbubba32 1987 - 1996 F150 & Larger F-Series Trucks 0 11-26-2011 02:03 PM
98 navi 5.4L p0353 code!! strongjm25 Expedition & Navigator 7 09-26-2010 03:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
