Battery only showing 10 volts
Is the 10v on a hand-held meter or a dash gauge?
Is the battery old, like 5 yrs?
You could try to charge it, if you have the means.
Also look for well over 14vdc to be read at the battery terminals, with the engine running, to be sure that the alternator is putting out.
Don't let yourself get stuck.
The battery is stamped with 2001 so it's old. I doubt my charger will touch it.
on
The factory voltmeter, like EVERY other gauge on the panel (even the tach and speedo), shows you an estimate. If you want a more precise reading of anything those gauges are measuring you have to do it yourself. Not just these trucks that do it, I ain't EVER seen a factory gauge on any vehicle that was accurate.
I laughed when I saw you had a battery from 2001. Down here the heat woulda killed it 4 times over. You get 2-3 years out of a battery before it leaves you somewhere you don't want to stay at... like out in the woods when the skeeters are fixin' to come out, or in a parking lot just before it's time for the regularly scheduled afternoon thunderstorm.
Better get that thing replaced even if it IS still good. I wouldn't trust it even if it don't get that hot where you are.
Even with my new battery (it was a cold winter), it will drop to around the N on the factory gauge while starting. Although with the truck off, the multimeter reads mid 12's like it should. Get a meter reading to know for sure, but I'd keep a spare battery in the truck for when it finally calls it good. Especially since your current battery is about 14 years old.
