1971 f250 camper special headers
Old 06-18-2015, 05:58 PM
droptine69's Avatar
droptine69
droptine69 is offline
Hello guys and gals....new here and I have a question.....im looking for headers that will fit my 1971 f250 camper special......has the 360 in it...has anyone found headers that will work....any help would be great
Old 06-18-2015, 09:14 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Before answering, questions for you;
1. 2WD or 4WD?
2. If 2WD, does your truck have a front swaybar mounted btwn the radius arms?
3. Auto or manual trans?
4. Auxiliary fuel tanks? Where
5. What is your budget on the low end and the high end?
6. Can you weld?
Old 06-18-2015, 09:27 PM
droptine69's Avatar
droptine69
It's 2 wheel drive.....no swaybar.....automatic.....2 tanks one on the side of the bed on drivers side up to the front......one behind seat....low to medium cost for now........can weld a little
Old 06-18-2015, 09:44 PM
HIO Silver's Avatar
HIO Silver
Thanks!
Well, installing a long tube header on the passenger side is a total pain. Most require undoing the engine mount and jacking up the engine to slide 'em up and in. Long tubes will also trap and convect heat on the starter.
The typical lo-buck choices are Flowtech and Hedman.
In the middle are Hooker Comp and Hedman Elites
The upper end are Stan's, Doug's, Doug Thorley, Mad Dog, and Sanderson (3/4-length). I went with Sandersons to simply avoid the pain the azz factor.
Cuz you got tanks along the frame rail ya might wanna look at fenderwell exit headers. Or ya gotta configure like stock with a merge pipe and/or duals running down the passenger side frame rail.
FYI:
FE Exhaust Manifolds and Why You Probably Want Headers
CarCraft Magazine: Build a Low-Buck Street/Strip FE
Ford FE.com: 332-428 FE Engine Forum
Sanderson Shorty Headers FF427 Reference Pics
Doug Thorley FE Headers
Barry Rabotnik's Survival Motorsports- FE Engines & High Performance Parts
Ford FE Smog-Legal Horsepower,Part I
Ford FE Smog-Legal Horsepower, Part II
Old 06-18-2015, 09:56 PM
droptine69's Avatar
droptine69
I'll go with sanderson then.....it has a 360 in it now....so which one would be best to go with style wise
Old 06-18-2015, 10:02 PM
HIO Silver's Avatar
HIO Silver
What do you mean by "style"?
Sanderson FF427 headers are spec'd for these trucks and fit like a glove. Refer to the link above.
Old 06-18-2015, 10:15 PM
droptine69's Avatar
droptine69
I see what ya mean now....thanks for the info.....gonna order some tomorrow
Old 06-19-2015, 02:17 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1. 2WD or 4WD?
All Camper Special's are 2WD thru 1976.
Ford didn't offer a front sway bar until 1973 for F250 2WD & F350 (it's unique for 1973/74). 1975/79 F100/250 2WD; 1975/78 F350 & 1979 F350 2WD use a different sway bar.
If a 1972 or earlier has a sway bar, it was installed by an RV dealer or front end shop.
Old 06-19-2015, 08:46 AM
HIO Silver's Avatar
HIO Silver
10.4.
Assume nothing.....Given the age and potential number of previous owners, it behooves one to ask the level of *******ization.
Old 06-19-2015, 02:11 PM
droptine69's Avatar
droptine69
I have another guestion.....where do I find a mini starter
Old 06-19-2015, 03:24 PM
greentruck72's Avatar
greentruck72
greentruck72 is offline
summit has mini starters, never ran one myself but will when I get my but in gear and work on my truck.
Old 06-19-2015, 05:07 PM
droptine69's Avatar
droptine69
Thanks....gonna go look now
Old 06-19-2015, 05:25 PM
HIO Silver's Avatar
HIO Silver
Order yourself their free catalog... order one from Jeg's too. Feel free to peruse what is available for the FE engines.
Here you go:
https://www.summitracing.com/catalog
Send me a FREE Catalog - JEGS - Free Shipping on All Orders @ JEGS
joshz
15
01-04-2010 08:49 PM
7d2 tutone
12-13-2007 06:50 PM
matlock
03-10-2005 11:18 AM
gslk1214
02-09-2003 09:04 PM
Quick Reply: 1971 f250 camper special headers
